Pioneer PD-65 clock replacement - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th October 2012, 02:28 AM   #1
schubert's Avatar
Default Pioneer PD-65 clock replacement
Has anyone tried to replace the clock in a PD-65? I've tried and can't get it to work - any assistance would be welcome. I followed both versions of the instructions pictured but neither one worked. I had no trouble with my PD-59!
Old 6th October 2012, 09:14 PM   #2
schubert's Avatar
Problem solved - mostly my own stupid fault, but for the record these instructions work (from Octave Electronics for the LClock in a PD-75, but it works for the HiFiDiy clock in a PD-65, except for the power):
Pioneer PD75
Clock Frequency 16,9344MHz
Converter type Pioneer PD2028A
The Crystal unit is placed under the copper can, situated closest to the middle of the CD player enclosure. The converter PC Board is unfastened, and taken carefully out of the chassis, the can is removed with a soldering iron.
Remove X512, and R511. Short circuit C517
On IC512:
Connect LClock Out to Pin 3.
Connect LClock Gnd to Pin 7.
+12V red wire is soldered to R651, no matter which side.
Clock upgrade in Pioneer PD-59 with PD2029A Legato Link DAC nacc18 Digital Source 3 23rd February 2012 05:09 PM
Clock Modification for Pioneer PD-D9 SACD Player Hercules Digital Source 2 30th November 2009 03:42 PM
Adcom GDA-700/Pioneer PD-65 vs Marantz SA-8001 budwiser Digital Source 0 26th October 2009 02:26 AM
Pioneer PD-65 Schem & Mods richardau Digital Source 14 4th September 2005 04:11 AM
PIONEER PD-65 Schematic?? bear Digital Source 4 15th August 2005 02:24 PM
Copyright 1999-2017 diyAudio
