Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Two DAC Concepts
Two DAC Concepts
Old 4th October 2012, 11:08 AM   #1
jmltinc is offline jmltinc  United States
Default Two DAC Concepts
Hello All,
Please help me understand a few DAC concepts so I may move on! I have a CS4397...
Why is there a choice of two VD sources - 3V and 5V? Is there an advantage or disadvantage to either choice?
The offset voltage. My understanding is this is to allow single-supply operation. Is this true? Can offset be minimized without losing SQ?
Thanks,
-John
Old 4th October 2012, 01:24 PM   #2
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
I didn't find a CS4387 on Cirrus' website. I'll assume you mean the, CS4397.
The choice of 3V or 5V digital supply voltage (VD), will be determined by the supply voltage requirement of the digital logic feeding the DAC chip. This is to provide flexibility at the DAC chip for accepting the logic signal levels from either a 3V, or a 5V preceding logic device.
Yes, the analog output voltage is necessitated by the unipolar aspect of the power supply. You generally have two options for dealing with this offset. you could directly feed the differential outputs to a differential buffer, which is usually what's recommended in such DAC datasheets. Or, you could instead block the D.C. offset utilizing coupling capacitors, but then you would still want to send the now A.C. coupled differential output signals to a buffer having differential inputs.
Old 4th October 2012, 01:38 PM   #3
naniking is offline naniking  Hong Kong
Originally Posted by jmltinc View Post
Hello All,
Please help me understand a few DAC concepts so I may move on! I have a CS4387...
Thanks,
-John
I think, in my concept:
- Some chips are using 3.3V, such as WM8741 which is DAC decoder.
- USB chips always using 5V that it can communicated with computer.
Just know CM6631.
Old 5th October 2012, 08:55 AM   #4
Yes, the DAC is a 4397. I edited the posting.
Thanks for the replies. I spent a lot of time trying to nail down what was very simple.
-John
Two DAC ConceptsHide this!Advertise here!
Audio Concepts. Legend P300. percival007 Solid State 12 20th April 2016 07:56 PM
Audio Concepts Orions need woofer help roline Multi-Way 0 6th March 2011 06:39 PM
Concepts Programmes Administration. Ltd soongsc The Lounge 0 6th January 2010 11:43 AM
Front loaded horn concepts rabw Full Range 62 25th May 2006 12:17 AM
Pre-amp system concepts Helix Solid State 0 5th January 2002 05:27 PM
