DC Offset to the dac - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th September 2012, 03:49 PM   #1
Default DC Offset to the dac
Hi, please how I can remove or minimize Dc Offset to ouptut of dac ?
i have misurated 1,75 volt ..
please help my !!!
thanks luigi
Old 25th September 2012, 04:03 PM   #2
merlin el mago's Avatar
Wich DAC?
Old 25th September 2012, 05:52 PM   #3
buffalo dac 3 : (
Old 25th September 2012, 06:27 PM   #4
Could you post on TP support forum Buffalo DAC - Twisted Pear Audio Support
Old 25th September 2012, 07:18 PM   #5
qusp is offline qusp  Australia
qusp's Avatar
hes obviously measuring the output of the dac module directly from one side to ground and getting the correct and expected DC voltage AVCC/2 and hasnt got an IV stage. was this really unexpected luigi? if so, i'm not sure you picked the right dac to build. its in the manual, thats what IV stages are for, there are many ways to get rid of it
Old 25th September 2012, 08:06 PM   #6
Default thanks
hi, thanks for your answer ,
my idea was to not use any active output should go well with the transformer (30k/30kohm) input to the my preamplifier
but the sound is not 'so good as hoped, then I think that both the dc offset that creates the transformer saturation or not a good fit with 784 ohm output impedence of the transformer dac with 30 k-30k
I do not know?
I'm trying to understand ...
Old 25th September 2012, 09:06 PM   #7
Pano is offline Pano  United States
Pano's Avatar
Doesn't the ES9018 have differential voltage outputs? I have an older model ES chip and it does. I use a transformer on its outputs and it works just fine. DC is blocked by the transformer. As the DC is common to the + and - outputs, the transformer primary actually sees no DC current.
This is typical of most voltage out DAC chips.
Old 26th September 2012, 06:26 AM   #8
please which transformer you use ?
thanks luigi
Old 26th September 2012, 05:11 PM   #9
Pano's Avatar
I use whatever I'm in the mood for.
Jensen, Cinemag, Peerless, Onectics, Edcor, Sowter. They all work, they all sound different. Any 1:1 will work OK. Or you can use a slight step up, like 1:1.4 or 1:2. They work well too. Load the secondary with about 3.3K in parallel to make the chip output happy. Somewhat higher if you use a step up.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 27th September 2012, 06:57 AM   #10
Thank for your answer,
but the dc offset 1,7 volt for buffalo dac not damage the transformer ?
it causes the transformer saturation ?
thanks luigi
Using PGA23XX with dac with dc offset nightanole Analog Line Level 3 9th May 2011 12:02 PM
add a volume control to a dac with dc offset nightanole Analog Line Level 1 5th May 2011 02:13 PM
DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? beady Solid State 6 17th March 2011 10:53 AM
NOS DAC DC offset issue dsavitsk Digital Source 7 15th July 2005 08:17 AM
Help With DC Offset Sybex23 Chip Amps 8 15th November 2004 07:11 PM
Copyright ©1999-2017 diyAudio
