Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th October 2003, 10:09 AM   #1
rwagter's Avatar
Default mains ps for DDDAC?
I just ordered a PCB for doede's dddac:
http://www.dddac.de
all voltafe regulators are on the PCB itself. Doede uses a battery as a powersupply.
I'd rather use a regular PS directly from mains (220V). The ultimate questions always is how to get a clean 12V to the regulators.
My first thought is use a regular 2x9V toroid with LCLC filter to get clean 12V for power to cs8412 and the clock and use a seperate supply also with LCLC filtering for the TDA1543.
Am I making any sense doing this.
Old 27th October 2003, 11:36 AM   #2
Andypairo's Avatar
I also plan to build (as soon as I receive the TDA1543 I ordered) a DAC similar to Doede's (even if I will probably use Elso's Asynchronous reclocker), without battery.
I was thinking about a CLC filter followerd by a 7812 for each 5V supply and a more elaborate (taken from the "Convertus") discrete PS for the dac itself.
Cheers
Andrea
Old 27th October 2003, 12:10 PM   #3
rwagter's Avatar
Andrea,
you mean this one ?
It looks simple enough. Why don't you use the complete PSU from tnt?
Ralph
Old 27th October 2003, 12:45 PM   #4
Andypairo's Avatar
I wanted to experiment a little and using local shunt regulators like the TL431 ( did I forget to mention them ? )allows me to choose whether using a separate supply for the analog and digital supplies or not (and eventually to re-use the receiver section with a 1541).
The DAC supply instead had to be variable since everyone seems to have a preferred voltage to feed the 1543...
Cheers
Andrea
Old 2nd November 2003, 05:46 PM   #5
Lucas_G is offline Lucas_G  Netherlands
I too would like to build the Doede Douma Dac with a mains-PSU instead of battery.
I am thinking of using the PSU that Fabian describes in this thread:
Pictures of another TDA1543 coverter
I also posted a question there about the neccesary changes to stuffing the DDDAC PCB when using the Fabain PSU...
Maybe someone can advise on this?
Lucas.
Old 2nd November 2003, 06:35 PM   #6
Happy Ears's Avatar
Arrow battery advantages
Hi . I don't see the advantages of building this DAC with regular power supply .. note that you need to arrange very clean 5 volt for the XO too ..
I compared both solutions and finaly dicided to go on with the battery .. it's far better . more relaxed sound , quiescency etc.
Just an opinion !
Happy Ears
Old 3rd November 2003, 07:18 AM   #7
Default Re: battery advantages
Just an opinion !
Happy Ears
Hi Happy Ears,
So you did a comparison on sound-quality?
I considered the Fabian PSU solution because I thought it would be more convenient. However if the battery-solution sounds substantially better, I will go for battery.
I wondered though how good the LM 317 T is?
Doesn't these regulators themselve produce noise?
Don't they need better filtering after them?
Are there any better alternatives?
Lucas.
Old 3rd November 2003, 07:30 AM   #8
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Like Doede says on his website..the LT 1085 is a good alternative..
Bas
Old 3rd November 2003, 08:28 AM   #9
Bas
Hi Bas,
I saw that the LT 1085 is ten times more expensive than the LM 317.
Is it indeed a lot better?
Lucas
Old 3rd November 2003, 03:24 PM   #10
Hi Lucas,
The short answer is : "I don't know"
Hopefully someone in the know will reply to your question...
But I seriously doubt it is 10 times better?
I don't know if they are the same...but I am going to use a LD 1085 as opposed to a LT 1085..
The LD 1085 is $1,30 at mouser...
Bas
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
FS: DDDAC USB Only - Assembled jeff mai Swap Meet 1 27th September 2006 04:42 AM
DDDAC 1543 DAC Mk2 Ulas Digital Source 16 9th June 2006 09:09 PM
DDDAC questions gchrist Digital Source 19 30th September 2005 04:43 PM
My dddac + some questions revell Digital Source 4 27th July 2005 09:57 AM
Page generated in 0.11283 seconds (80.18% PHP - 19.82% MySQL) with 11 queries
