Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Seek superb clock circuit for ADC ...
Old 21st September 2012, 09:33 AM   #1
gentlevoice is offline gentlevoice  Denmark
Default Seek superb clock circuit for ADC ...
Hi diyers,
I'm currently working on an ADC based on the PCM4202 from TI:
http://www.ti.com/lit/ds/symlink/pcm4202.pdf
The PCM4202 is a CMOS device that operates with a 3.3 volt digital supply and similar clock signal level.
I will be using this crystal from NDK:
Clock Selection Experts?
I will be using only one crystal at 22.5792 MHz so I need a very simple - yet in terms of jitter phase noise - superb circuit for interfacing it to the PCM4202.
Any of you know of such a circuit and can post a link or a schematic?
Thanks for reading & maybe replying
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 24th September 2012, 07:31 AM   #2
oho ... nobody has suggestions ...? I'm really interested in finding such a circuit.
Greetings,
Jesper
Old 24th September 2012, 01:32 PM   #3
marce is offline marce  United Kingdom
A short trace, as short as possible from the crystal to the chip. With the loading capacitors etc.
Old 24th September 2012, 07:52 PM   #4
Hi Marce,
& thanks for replying ... It's interesting actually that I've been surfing around DIYaudio a good part of the day trying to find a schematic of how the clock circuits look like for the numerous ADs & DAs designed & built here. And besides a few schematics like e.g. Elso Kwak's I've found very little ... Maybe people here just know what is the best way to connect a crystal to a DAC or ADC or I may not know how to search ...?
Anyway, I've found these circuitries in different internet sites, but I don't know if either of them will lead to the best possible clock (please see thumbnails).
They are actually quite similar but maybe one of them - or a completely different circuitry - is better? Could it be that the PO74 inserted into the first thumbnail would be a feasible way to go for the best result?
Or might there be an advantage with Elso Kwak's circuitry compared with the other circuits?
About short traces I am aware of this and also shielding the clock with e.g. a ground plane.
Although the PCM4202 may not be the best AD converter around I'm hoping to make a clock circuitry that can also be used for later - possibly - better designs.
Insights are appreciated
Jesper
Old 24th September 2012, 07:59 PM   #5
Ervins is offline Ervins  Latvia
Default LJC
look here
Discrete Low Jitter Clock GB
Old 24th September 2012, 08:17 PM   #6
s3tup is offline s3tup
s3tup's Avatar
Then find a goooood power supply schematics (extremely low noise, especially at low frequencies, and buy the crystek (the larger one, not the tiny SMD).
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 25th September 2012, 08:34 AM   #7
If you want the ultimate clock circuitry look for discussions on communications telecom clocks etc
A decent oscillattor or crystalnext to the clock input pin is best, running clocks through wires or over a distance is detrimental to the signal.
Old 25th September 2012, 03:30 PM   #8
Hi all,
& thanks for your replies. I think I have a better grasp now of what I would like to do - seems the NDK oscillator actually just needs a good power supply to work :-)
Greetings!
Jesper
Seek superb clock circuit for ADC ...Hide this!Advertise here!
CD Clock circuit audiobard Digital Source 42 17th November 2011 02:42 AM
Audio protection circuit for microprocessor ADC? Neil_J Digital Source 1 26th June 2007 08:33 PM
Seek AGC circuit with low distortion for subwoofer! GPE Analog Line Level 1 3rd January 2007 10:40 PM
help with clock circuit pho_boi Digital Source 10 7th November 2006 01:20 PM
Clock Oscillator circuit argonrepublic Analog Line Level 5 30th January 2006 03:48 AM
