Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
UNIO a minimalist I/V converter
Old 20th September 2012, 06:53 PM   #1
smms73 is offline smms73  Portugal
smms73's Avatar
Default UNIO a minimalist I/V converter
This is my minimalist I\V converter that i call UNIO.
It was designed based on the opinions i get from the other two thread that i start.
The almost universal opinion is that simple is better.
I have already build a prototype and i am very impress by the very good performance that this simple circuit produce.
This is intend to be use with a pcm1794a. but it can be redesign to work with others DAC.
the output voltage is 1Vrms in balanced mode or 0.5 Vrms non balanced.
SÚrgio Santos
Old 20th September 2012, 07:02 PM   #2
smms73's Avatar
This is some distortion measurements of the prototype.
the first image is from the emu1212m alone ( the distortion is a little bit higher than normal because the low impedance load 565 ohm).
the second image is the output distortion with 0.7 Vrms
the third image is with 1Vrms.
This test was done with full balanced input and output.
SÚrgio Santos
Old 20th September 2012, 07:07 PM   #3
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
On what level is the DC offset at the input ?
Old 20th September 2012, 07:10 PM   #4
smms73's Avatar
The prototype was built with 5% resistors and polyester output capacitors.
And the power supply was not very good.
For better performance use 0.1% resistors in R1, R2, R5, R9, R17, R18.
C0G ceramic capacitors for C3, C4, C5
Polipropilene capacitors for C1, C2
And is very important to match the transistors. And of course use a very low noise power supply.
SÚrgio Santos
Old 20th September 2012, 07:15 PM   #5
smms73's Avatar
Hello Joachim.
with 6.2mA will be 34mV with a 5.6 ohm input resistor
SÚrgio Santos
Old 20th September 2012, 07:16 PM   #6
zxgravediggerxz is offline zxgravediggerxz  United States
Very nice Sergio! Definately worth a look when I am doing my 1794a DAC
How did you take those ARTA measurements? I am curious to see a pic of your setup, because I am interested in doing my own measurements with ARTA too but I havent figured it out yet :/
This is not reality...
Old 20th September 2012, 07:27 PM   #7
smms73's Avatar
Thanks zxgravediggerxz .
I don┤t know if i understand your question, can you be more specific. What is the difficulty you have ?
I use a emu1212m sound card.
SÚrgio Santos
Old 20th September 2012, 07:31 PM   #8
smms73's Avatar
Forget to say that V3 is a blue led but you can also use a shunt voltage reference like tl431 , the output of the current source is 25mA.
SÚrgio Santos
Old 20th September 2012, 07:40 PM   #9
lcsaszar is offline lcsaszar  Hungary
Can't Q1 and Q2 be in common base topology, i. e. the base and emitter swapped?
Old 20th September 2012, 07:45 PM   #10
smms73's Avatar
Unfortunately no.
with a common base you will have zero common mode rejection ratio .
SÚrgio Santos
UNIO a minimalist I/V converterHide this!Advertise here!
Minimalist A/B fet amplifier plp Solid State 26 7th May 2018 04:47 PM
Minimalist PL519 OTL? Spasticteapot Tubes / Valves 26 27th May 2010 08:58 PM
Minimalist Mosfet amp Spiny Solid State 13 11th March 2008 06:40 AM
Minimalist DAC: is this possible? beppe61 Digital Source 12 27th July 2005 09:08 AM
Where can I get schematic of a minimalist LM3886 for sub use ? goldyrathore Chip Amps 4 1st June 2005 03:11 PM
