Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th September 2012, 04:22 PM   #1
lassipr is offline lassipr  Finland
Default Shanling cd-s100 mods?
Hi
Anyone any experience about this? Any suggested mods? Is it worth to mod it?
Old 21st September 2012, 02:47 AM   #2
I would give it a qualified "maybe". The PCM1732 is a v-out dac, with hdcd digital filter built in, so it's very limited as to what can be modified. Have not ever heard this chip, myself, so don't know how good it can be. There is a very easy & easily reversible mod you can try to see how much potential it does or doesn't have- Since it's got i/v & lpf opamps built in, you can take the outputs directly from the the dac chip to the output jacks, with just the output dc blocking caps in the signal path. All you need to do is connect either the existing or an added set of rca jacks to the capacitors that come from pin 13 for R ch, and pin 16 for L ch. Disconnect one side of each cap, so that each is only connected to chip pin & line to output jacks. This will bypass the unneeded two opamp stages & tell you if the dac will sound worthy of then upgrading the power supply to it, and the caps for the output pins.
Upgrade output Shanling CD-S100 MkII CeeVee Digital Source 233 3rd March 2012 07:05 PM
Shanling Cd-S100/ Music Hall 25 (25.2) fluorescent display source? limono Parts 2 5th August 2011 01:22 AM
CD Player laser fault/misdiagnosed (SHANLING S100) nathanjh13 Digital Source 18 15th December 2010 01:28 PM
Mod SHANLING CD-S100 fred78 Digital Source 0 4th January 2008 11:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
