Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
DAC-END R (ES9018)
DAC-END R (ES9018)
Old 9th October 2012, 03:20 PM   #21
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign DAC-END R (ES9018)
In the near future will be available a module to modify the configuration of the ES9018 with infrared remote control.
The main functions:
- input selection spdif, toslink, dsd and i2s
- volume
- mute
Old 12th October 2012, 06:45 AM   #22
quanghao is offline quanghao  Viet Nam
DAC-END R (ES9018) Send a message via Yahoo to quanghao DAC-END R (ES9018)
The main functions:
- volume
- mute
hi! audiodesign , you finis write code for volume DAC!
thanks
Old 12th October 2012, 06:48 AM   #23
I have complete kit DAC-END 32, I am very pleased with the sound of it!
Invite the doctor to see the pictures!
Old 25th October 2012, 05:49 AM   #24
Hi Audiodesign!
You can take the test images DAC-END 32 up for all to see!
Thank you!
Old 25th October 2012, 05:58 AM   #25
Banned
Looking for a good I/V for this project I have started a series of test with output transformers.
There is another thread about ES9018 and transformers.
Buffalo II & transformers
The trasformers can be placed bofore or after the resistors of the I/V.
I have modified the schematic of Joe Rasmussen.
Old 25th October 2012, 06:00 AM   #26
Banned
In the measurements the second solution give better performances but ....
(see the name of files)
Old 25th October 2012, 06:19 AM   #27
Banned
The 200ohm should seen on primaries like a 200 / (4 * 4) = 12.5 ohm
but if we add also the static resitance of the primaries and secondaries
the new calculation give:
(200 + 605 + 605 / (4 * 4)) + (33 + 33) = 154 ohm (to divide for 2 prim.)
so probably the frequency response is better with the I/V resistor after the transformer becasue the ES9018 is working in voltage and not current.
Old 25th October 2012, 06:22 AM   #28
Banned
I will make some more test with LL1684 1+1:1 this evening but until now I don't consider a good idea to use the transformer on output of ES9018.
The frequency response is too bad on low frequency.
Old 25th October 2012, 03:43 PM   #29
reactivepower is offline reactivepower  Canada
I used a pair of Jensen output transformers directly connected to the ES9018 output and was quite happy with the sound. I selected the Jensen because they seemed to be built on science and theory not snake oil. Jensen also has a well written book on audio transformers on their website. I used the JT-10KB-D step down transformer to give me 0.6 V output, which was perfect for the gain of my amp. Also, I picked a slightly higher resistance than recommended on the output and loaded it with my amp input impedance in parallel to give the right value. It worked really well and I was quite happy with the low end. I had tried another configuration with an I/V stage before the transformer but found the low end frequency response to be rolled off. Maybe just try different configurations with the transformers you have to see if you can get the sound you are looking for.
Old 25th October 2012, 05:45 PM   #30
Banned
reactivepower, Have you measure it ?
Many DIY use transformers without measurements and they think to ear a good sound but in reality they are losing many details because there is many problems on frequency response.
Certainly I don't know if you have these problems and I don't know if you are using the ES9018 as voltage output.
The trasformes and choke have many many bad effects on frequency band and only with a set of measurements these can be found.
DAC-END R (ES9018)Hide this!Advertise here!
ES9018 DUALMONO DAC KIT heartwinter Vendor's Bazaar 7 15th September 2012 09:40 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
ES9018 DAC chip McCrackers Swap Meet 1 5th November 2011 12:15 PM
FS Saber32 ES9018 DAC (chip only) randytsuch Swap Meet 2 19th September 2011 10:53 PM
Help me pick a dac? $500 range. ES9018? Docks Digital Line Level 6 7th May 2011 10:07 AM
