Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
DAC-END R (ES9018)
DAC-END R (ES9018)
Old 25th November 2012, 03:12 PM   #91
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign DAC-END R (ES9018)
The test are finished, the new ES9018 DAC with the Amonero module is able to play 44,88,96,192,384KHz, DSD file and SACD iso images.
The firmware remap the DAC to share the same input pin for PCM and DSD without hardware changes.
We will integrate the Amonero module to get a very short I2S wire.
See news on:
ES9018 USB DAC - Hi-Resolution System
Old 25th November 2012, 03:18 PM   #92
fredlock is offline fredlock  United States
How much is the cost of DAC-END R? Are you guys selling it as a kit? or assembled, ready to use? Can you you give us details?
Thanks,
Fred
Old 25th November 2012, 03:27 PM   #93
Banned
The ES9018 DAC will be an assembled module without output stage and it will cost about 300$, Amonero USB-I2S/DSD module cost 97$
There are 2 options for the output stage, the vaccum tube stage is very simple and it can be assembled on air without pcb.
After the first definitive test on the last pcb we think to start a list of pre-order to reduce the cost of production.
Old 25th November 2012, 03:50 PM   #94
Do you think the price would go down a bit if theres a lot of interest, for the introductory price of this DAC? Can you give us the dimension of the DAC board? How about the controller module? I think that's a cool feature to include on this DAC. How much do you think would it cost?
Sorry for the asking to much question.
Thanks,
Fred
Old 25th November 2012, 04:01 PM   #95
quanghao is offline quanghao  Viet Nam
DAC-END R (ES9018) Send a message via Yahoo to quanghao DAC-END R (ES9018)
Thanks,
Fred
DAC board size: 11 cm X 20Cm.
Old 26th November 2012, 12:17 AM   #96
kocurmarcin is offline kocurmarcin
How does Your dac compare with bufflo III ?
Old 26th November 2012, 12:40 AM   #97
qusp is offline qusp  Australia
qusp's Avatar
it would be unprofessional of him to comment... why put him in that position?
Old 26th November 2012, 07:53 AM   #98
Buffalo is similar product. As a designer hi knows good an bad points of his dac and deferences , if any. Unprofessional it would be if i ask to judge Buffalo , maybe i ask wrong question . In that case i would like to ask what deferent from Buffalo.
Old 12th December 2012, 07:18 AM   #99
This Finis DAC
Old 12th December 2012, 07:27 AM   #100
Banned
The DAC module develop with Quanghao use separated fast shunt for all the power supply of ES9018 and for the oscillator.
It have 4 input: spdif RCA, spdif toslink optical, AES/EBU XLR professional standard and USB to play PCM and DSD files.
Here some more info about:
A controller module is integrated to display on LCD Volume level, input type and more info about the configuration.
All the controller mode functions can be changed with a simple remore control.
DAC-END R (ES9018)Hide this!Advertise here!
ES9018 DUALMONO DAC KIT heartwinter Vendor's Bazaar 7 15th September 2012 09:40 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
ES9018 DAC chip McCrackers Swap Meet 1 5th November 2011 12:15 PM
FS Saber32 ES9018 DAC (chip only) randytsuch Swap Meet 2 19th September 2011 10:53 PM
Help me pick a dac? $500 range. ES9018? Docks Digital Line Level 6 7th May 2011 10:07 AM
Copyright ©1999-2017 diyAudio
