diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   DAC-END R (ES9018) (http://www.diyaudio.com/forums/digital-source/220006-dac-end-r-es9018.html)
quanghao 19th September 2012 09:59 AM
DAC-END 32 bit
8 Attachment(s)
After the success of DAC-END with Andrea Ciuffoli:
DAC End - the AD1865N-K with single ended vacuum output stage
DAC End 2 - the AD1865N-K with single ended vacuum output stage
Andrea and Quanghao continue to study the DAC, with ES9018 chip, a DAC chip and new potential.
After nearly two years of support from chip manufacturers and work with Andrea, He and I had initial success with the 32-bit DAC, we call it the
DAC-End R.
The sound is Very detailed and balanced, high fidelity, very impressive to me!
These are the first images of the DAC-End R
Thanks you!
quanghao 19th September 2012 10:24 AM
1 Attachment(s)
Here is the block diagram of the DAC-END R.
Maybe we'll put the volume control , input and output and more.
Output: Tube or IV opam.
Power supply used for DAC , we use many separate Shunt regulater.
qusp 20th September 2012 08:05 AM
I really think ESS needs multilayer PCB
abraxalito 20th September 2012 08:20 AM
Originally Posted by quanghao (http://www.diyaudio.com/forums/digital-source/220006-dac-end-r-es9018-post3170652.html#post3170652)
So the $64,000 question - does it sound better than the AD1865 or is this just to accommodate customers who want more bits?
quanghao 20th September 2012 08:43 AM
1 Attachment(s)
Originally Posted by qusp (http://www.diyaudio.com/forums/showthread.php?p=3171821#post3171821)
I think a good layout design does not need to use the multi-layer PCB.This is my layout!
thank you very much!
quanghao 20th September 2012 08:47 AM
Originally Posted by abraxalito (http://www.diyaudio.com/forums/showthread.php?p=3171842#post3171842)
It is better technology, and new.
Dac-end) AD1865) close and natural sound quality, it has conquered my system; Ntday today, I want to find new ones, and there are many options such as USB input,
32-bit DAC-potential,
DAC-END is the standard DAC for my system!
thank you!
abraxalito 20th September 2012 08:51 AM
Sounds like a no then - I appreciate your honesty. So you are adopting ESS9018 because its getting harder to obtain AD1865 chips (they're discontinued by ADI AFAIA)?
quanghao 20th September 2012 08:53 AM
Originally Posted by abraxalito (http://www.diyaudio.com/forums/showthread.php?p=3171862#post3171862)
yes!
thanks your advance!
Quanghao
quanghao 20th September 2012 09:03 AM
DAC layout is not a simple job, always need separate DGND and GND.Need to calculate properly, and connecting them together, and the energy supply for the function of the chip!
In terms of the multi-layer PCB is the best choice, but with the existing conditions, 2 layer PCB is easier!
thanks
analog_sa 20th September 2012 09:20 AM
I think you already know the answer: it sounds much better but not at 44/16 :)
Copyright 1999-2017 diyAudio
