DAC-END R (ES9018) - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th October 2012, 06:55 PM   #31
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
To create a set of measurements is necessary only a normal sound card and the freeware Arta software.
Old 26th October 2012, 12:23 AM   #32
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by reactivepower View Post
I used a pair of Jensen output transformers directly connected to the ES9018 output and was quite happy with the sound. I selected the Jensen because they seemed to be built on science and theory not snake oil. Jensen also has a well written book on audio transformers on their website. I used the JT-10KB-D step down transformer to give me 0.6 V output, which was perfect for the gain of my amp. Also, I picked a slightly higher resistance than recommended on the output and loaded it with my amp input impedance in parallel to give the right value. It worked really well and I was quite happy with the low end. I had tried another configuration with an I/V stage before the transformer but found the low end frequency response to be rolled off. Maybe just try different configurations with the transformers you have to see if you can get the sound you are looking for.
I plan to do the PCB has the following output:
1. DAC output signal directly-you can use the manufacturer's standard IV with 3 opam A797.
2. DAC using the or iV Output used a pre opam or tube
3. DAC output signal through a transformer LL1674 or equivalent. You can buy it and add your own.
Old 26th October 2012, 12:28 AM   #33
Old 26th October 2012, 12:37 AM   #34
and this is the lyout part complete DAC-end R.with the following dimensions:
110 mm x 210 mm.
I plan to do with all kit components paste, used industrial welding machines.
Note that the kit is not LL1674 transformer, you need to purchase it separately and welding kit.
You look at this project, thank you!
Old 26th October 2012, 12:02 PM   #35
Ciu is offline Ciu  France
Originally Posted by audiodesign View Post
Looking for a good I/V for this project I have started a series of test with output transformers.
There is another thread about ES9018 and transformers.
Buffalo II & transformers
The trasformers can be placed bofore or after the resistors of the I/V.
I have modified the schematic of Joe Rasmussen.
Hello !
Speaking about left D schematic (resistors on primary):
Did you test also, but without grounding CT on primary ?
I didn't have measured, but to "my ears", it sound better with only one resistor (6 ohms) across primary, and x50 tube stage.
Richard
Old 26th October 2012, 12:13 PM   #36
Originally Posted by Ciu View Post
Hello !
Richard
yes, i use the iv passive 5R ( parallel 2x 10R) but i not use out put tranformer, I use balnce op am. the sound i like!
Old 26th October 2012, 12:36 PM   #37
Banned
Hello !
Richard
Where you connect the central ?
Old 26th October 2012, 04:26 PM   #38
Hello !
I don't have any central .... I use Jensen JT-11-emcf transformer
The resistor is across the primary, the + - are always 180 of phase, so the current is flowing, and as ESS said early, the ESS9018 output is "sourcing/sinking"
Would you explain the "theory" with CT grounded, and if you could test, it would be nice
Old 26th October 2012, 07:25 PM   #39
Banned
Here the new measurement with low I/V resistances, the LL1684 with a turn ratio 1:1 is not bad
Old 26th October 2012, 07:49 PM   #40
Banned
If we use the tranformer we don't need a balanced differential vacuum tube stage so we could use this circuit.
It is a variation of the TEM 3200 6moons audio reviews: Thorens TEM 3200
It is a DC coupled vacuum tube stage without the output capacitor.
The negative voltage is variable with an auto-set to get always zero volt on output.
The second stage is driven on g2 grid and the low global feedback is optional not necessary.
ES9018 DUALMONO DAC KIT heartwinter Vendor's Bazaar 7 15th September 2012 10:40 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 09:50 AM
ES9018 DAC chip McCrackers Swap Meet 1 5th November 2011 01:15 PM
FS Saber32 ES9018 DAC (chip only) randytsuch Swap Meet 2 19th September 2011 11:53 PM
Help me pick a dac? $500 range. ES9018? Docks Digital Line Level 6 7th May 2011 11:07 AM
Copyright 1999-2017 diyAudio
