DAC-END R (ES9018) - Page 13 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th January 2013, 03:30 AM   #121
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by quanghao View Post
2. Very good individual components, industrial welding machine, lead-free pewter.
From a DIYer's perspective, the use of lead-free solder is a bug, not a feature. Its terrible to re-work - any chance of using normal 60/40 solder?
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 8th January 2013, 05:03 PM   #122
Can you say Audio?
Can you provide just a little more information about the kit? Apologies - it may be due to language translation:
1) What if any components/modules come assembled? All? It seems they do (inspection and testing) but I want to be clear.
2)Welding machine, lead-free pewter - is a case included?
3) Apart from connectors and a USB receiver - what else is needed?
Excited about your work, just need more info :-)
Old 8th January 2013, 11:01 PM   #123
Anyone know any reason why my lead free DAC chips slowly develop a grayish color residue/contaminant around the pins after the chip is soldered to the PCBS? Eventually, this residue causes increasingly audible distortion until I clean it off with contact cleaner spray, but then the residue build up slowly again. This chemical reaction residue, or whatever it is, has appeared with multiple PCM1794A chips I've mounted. I'm thinking this is being caused by some kind of reaction between the lead-free pins of the chip and the lead bearing solder of the pre-tinning PCBs provided by my board supplier, but I really don't know. Anyone else had this problem, or know what is causing it?
Ken
Old 10th January 2013, 10:45 PM   #124
i2k92 is offline i2k92  Indonesia
I guess what he means by no 2 is soldered by machin using, lead free solder (to be ROHS compliant).
Old 10th January 2013, 11:35 PM   #125
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
1 x Kit DAC
2 x Kit IV
1 x Volum Kit + Remove
all tested
thanks
Old 10th January 2013, 11:37 PM   #126
you can buy it: Amanero Technologies
and put in the DAC , and run from computer
thanks
Old 10th January 2013, 11:42 PM   #127
Can you say Audio?
I'm sorry Quangho - I may not be making myself clear, but your posts do not address any of my questions. Let me try again.
1) Is the Dac kit assembled? Yes? No? Partially?
2) Are the IV Kits assembled? Yes? No? Partially?
I have a couple Combo384's and no how to use them - thanks. I wanted to know what else would be needed for a complete DAC.
Case? Power Transformers?
Thanks Quangho - we'll get there :-)
Old 11th January 2013, 12:00 AM   #128
[QUOTE=MisterRogers;3320408]I'm sorry Quangho - I may not be making myself clear, but your posts do not address any of my questions. Let me try again.
Yes
Yes
3, 1 x Volum Kit + Remove assembled?
yes
you only put on the dac, and use the remove controller and play the music
You need transformer for dac
1. 0-6 VAC to 9VAC/ 1A x 2 for DAC
2. 18-0-18VAC/500mA x 2 for IV
3. And one Combo384's ( only put in the DAC )
You have a DAC
thanks
Old 11th January 2013, 12:04 AM   #129
Can you say Audio?
Perfect! Thanks Quangho!
Old 11th January 2013, 06:10 AM   #130
I am interested. I presume you will only make the boards after 50 orders received rather than 50 orders minimum per person?
ES9018 DUALMONO DAC KIT heartwinter Vendor's Bazaar 7 15th September 2012 09:40 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
ES9018 DAC chip McCrackers Swap Meet 1 5th November 2011 12:15 PM
FS Saber32 ES9018 DAC (chip only) randytsuch Swap Meet 2 19th September 2011 10:53 PM
Help me pick a dac? $500 range. ES9018? Docks Digital Line Level 6 7th May 2011 10:07 AM
Copyright 1999-2017 diyAudio
