I2S to S/PDIF - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th November 2012, 03:39 AM   #11
linuxworks's Avatar
I have not used the TP board but I have built my own from perf and I used a 12mhz xtal, as exactly per the spec sheet (12 is the only choice you have in HW mode). I have not used sw mode yet but anything below and including 96k 'just automatically works' in hw mode.
maybe I got lucky with all the right i2s lines. I had to do zero work other than connect 3 clocks and 1 data to the chip, set it up as an spdif transmitter and whatever rate I put in from the audio widget, the wolfson obliged and I was able to see all the samplerates come out.
the chip is great for spdif tx.
its spdif-rx that it has limited success in, for hw mode and 176/192k.
but when you send it i2s, I have not found a SR that did not work, including 44.1
My Photostream:http://www.flickr.com/photos/linux-works/
Old 26th November 2012, 05:18 AM   #12
Originally Posted by leres View Post
I was able to get a CS8406 working but I needed to find OMCK and feed that to the CS8406 in addition to SCLK, LRCLK and SDIN. I had a lot of dropouts but I think it was because I had wires everywhere and nothing was shielded. I'm going to wire up a permanent version this weekend and see if I can make it work better.
I finally had a few minutes to play around and now that I know all 4 signals needed (serial data, serial clock, L/R clock and master clock) I was able to get both the cirrus CS8406 and the wolfson WM8804 to produce S/PDIF.
Old 11th July 2016, 04:22 AM   #13
I've done some more work with my WM8804 circuit and have learned a couple of interesting things.
A new I2S source did not have master clock accessible but I was able generate it with a Cirrus CS2300-03 PLL clock multiplier. I multiplied the bit clock by 4 the WM8804 was happy to output S/PDIF.
One thing interesting about the first version of this circuit was that it did not include the 12 MHz crystal. This makes me wonder if S/PDIF re-clocking occurs when the input source is I2S.
Something I had a difficult time getting working was a "lock" LED. My read of the data sheet makes me believe the 4 status lines you have access to when operating in hardware mode (TRANS_ERR, GEN_FLAG, NON_AUDIO and UNLOCK) all apply to the S/PDIF input signal.
Today I got the idea to feed the generated S/PDIF output back to the the S/PDIF input. That worked! Well, it worked with my Twisted Pear S/PDIF transceiver module anyway. Figuring that the S/PDIF input logic needs the crystal, I added one and that allowed me to see all good status lines.
I've also been puzzled why NON_AUDIO is always indicated. I believe this is because PCM_N means non-PCM such as compressed, surround sound, Dolby, etc. is not detected when the chip is fed with PCM (and obviously no non-PCM formats are detected when there is no input).
Anyway, fun little chip!
I2S to S/PDIF converter krassyg Digital Line Level 2 13th October 2011 01:31 PM
Multichannel I2S to S/PDIF converter lacipeti Parts 0 5th October 2011 12:15 PM
I2S-S/PDIF 2:1 Mux Receiver merlin el mago Twisted Pear 7 2nd April 2011 06:04 PM
Capture 3x (6 ch) I2S or S/PDIF macboy Digital Line Level 10 28th April 2010 06:34 PM
distribute S/PDIF or I2S, passive? tschrama Digital Source 14 23rd May 2003 12:22 AM
Copyright 1999-2017 diyAudio
