Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sony SCD-X501ES problem
Old 5th September 2012, 03:14 PM   #1
brennesel1 is offline brennesel1  Germany
Post Sony SCD-X501ES problem
Hallo,
my Sony SCD-X501 ES (4 years old) used to be a fine machine, but now it has a problem. It takes very long to read the discs, and more and more it ends with "no disc." Laser lens is clean. Sony says, change laser unit (transport and motor included, 180$, "servive assembly DBU-3").
What to do?
Does anyone know the laser pickup type (KSS?)
Does anyone have the service manual?
Thanks for helping.
Best wishes, Christoph
Old 7th September 2012, 01:53 AM   #2
konfokal is offline konfokal  Germany
I own the same model. Thermal stress ages Laser-diodes, even if the player doesn't play music but is only switched on. Is there a difference in reading CDs and SACDs?
Before exchanging the (double-)laser pickup Type DBU-3 you might try to increase the laser power: on the bottom side under the black pick up head you will find two potis, one for each laser system. Mark or memorize the starting position of the cross slots and then turn them clockwise, but be careful, only in very small steps of ca. 30 degree (resp. 1 hour on the imaginated clock) or less. This may help for a while. Unfortunately increased power will further shorten the lifetime of a diode. So switch off the unit everytime you don't use it and be prepared to order the DBU-3 in a not too distant future...
Old 7th September 2012, 02:05 AM   #3
Before exchanging the (double-)laser pickup Type DBU-3 you might try to increase the laser power: on the bottom side under the black pick up head you will find two potis, one for each laser system. Mark or memorize the starting position of the potis cross slots and then turn clockwise, but be careful, only in very small steps of ca. 30 degree (resp. 1 hour on the imaginated clock) or less.
Unfortunately increased power will further shorten the lifetime of a diode. So switch off the unit if you don't use it and be prepared to order the DBU-3 in a not too distant future...
Good luck, Mathias.
Old 7th May 2013, 10:50 AM   #4
Default to matthias
Lieber Matthias,
danke fürs antworten. ich war länger nicht mehr auf der seite. das gerät ist seit langer zeit bei einem experten, der das problem genau so beschrieben hat, wie du. er hat den (er sagt: letzten) neuen dbu-3 laser in den usa erstanden, kann ihn aber ohne service manual nicht justieren. kannst du weiterhelfen? mit einem manual?
Mit freundlichen Grüßen,
Christoph
Old 7th May 2013, 11:13 AM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
English please Cristoph.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 7th May 2013, 12:46 PM   #6
Extreme_Boky is offline Extreme_Boky
Originally Posted by brennesel1 View Post
Hallo,
What to do?
Thanks for helping.
Denon 2900
Sony SCD-X501ES problemHide this!Advertise here!
Sony SCD-1 & SCD-777 Spare Parts for Sale fas948 Swap Meet 5 30th August 2013 05:16 AM
Buffalo DAC on a Sony SCD-1/SCD-777? fas948 Digital Line Level 6 9th June 2009 08:02 PM
Sony scd-1 shepperd Digital Source 3 31st May 2007 10:35 PM
Sony Scd-xa777es markhod Swap Meet 0 14th July 2006 08:09 AM
Sony scd-xb770 read problem. air Digital Source 6 21st April 2004 02:41 PM
