| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I think the motor that rotates the cd has malfunctioned. I have a modded Rotel RCD-971 and was installing a 5v positive voltage regulator and cap at the time. And now when I turn the unit on the motor "tries" to spin and focus the lens, but because it cannot spin the display reads 'No disc'. There is some juice flowing through it; it seems to sputter a tiny bit but not enough to keep going.
Perhaps I have shorted something out while doing the install (everything else seems to be fine) or maybe the voltage regulator (I was replacing a JRC 7805A) isn't able to supply the correct amount of power? I'm fairly certain the voltage regulator affects the transport. I double checked the solder joints. It could simply be that the motor is worn out after all these years, in any case, here is a pic of the part I might need. It comes from a Sony KSL-2130CCM transport, but I'm having a hard time finding a better replacement or the motor I need. Can anyone help me out? I can post more pics or a full schematic, if necessary. |
#2 |
It coyld well just be the laser which is gone. Once it can focus the motor should work. But again the whole mechs dont cost much.
#3 |
Appreciate the advice, justubes. Never occurred to me that I should just replace the entire mechanism. Maybe that will also get rid of the noise I was hearing from inside long before it stopped working.
![]() I'm gonna pick one of these up next week. Original Sony Optical Pickup | KSM-213CCM (KSM213CCM) | Distributed By MCM |
| Rotel RCD-971 gone haywire | Alexdad54 | Digital Source | 53 | 1st November 2012 12:06 PM |
| Rotel RCD-971 Issues | CR500 | Digital Source | 25 | 14th February 2011 09:47 PM |
| Rotel RCD-971 mods | Telstar | Digital Source | 0 | 27th December 2007 06:08 PM |
| Looking for a Schematic for a Rotel RCD-971 CD Player | dtm1962 | Digital Source | 3 | 27th July 2006 03:50 AM |
| shematics of ROTEL RCD-971. | guytou | Digital Source | 6 | 29th May 2005 11:03 AM |
