| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#31 |
Banned
It does stink, but.......
I am glad that Terry was paying attention. I am even more glad that he is happy with the results. Jocko |
#32 | |
Banned
Any schematic? Or is it just a one transistor emittor follower? Is it at the DAC(receivers end) or at the CD players end? Thanks in advance. Interestingly when I did a search for cable drivers and receivers I found the receivers seem all to use Schmitt triggers! Elso/only using SPDIF for satellite receiver |
#33 | |
Or eliminate the problem: clock at dac with feedback to player. Async Fifo on the incoming signal(s). It then should not matter that there is a spdif connection before the fifo or that it is a direct i2s connection. (toch?) Clock is at the DAC and the data is clocked out of the fifo on this clock. If the filling of the fifo is jittery, so what. It has two async clocks. You know, i think, that i'm working in this (slowly). GuidoB
GuidoB |
#34 | ||
Terry: Yes, I've heard some great hype about the new TI ASRC's. I think they are the SRC4192 (hardware control) and SRC4193 (software control). I have some samples on order, but they are on back-order. Leave it to BB to use the SSOP package to annoy us DIY PCB makers... Oh, and the performance... WOW. The "grass" is indeed below -160dB... about -175dB with a -60dBFS 1kHz input! THD+N of -140dBFS... flat line with an input amplitude (1kHz) of -140dBFS to 0dBFS! That's pretty impressive stuff... Quote:
Like I said, one of the objectives of this was to be able to hook it up to any player with an SPDIF output. I'd like to make a version that I can build for friends that won't want me to rip apart their players.... or rather that I don't want to spend 10 hours figuring out how do mod each one of thier players ![]() Thanks all for the comments,
Tieftoener -- You're ears can sense a movement in air that causes your eardrum to move less than 1/10th of the diameter of a Hydrogen atom! Don't abuse the one of the most amazing organs your Creator gave you! |
#35 | |
Banned
Basically I am using a NON-OS DAC. This implicates I don't need the masterclock in the DAC. So why sending it from the DAC to the transport? And this is DIY. Three cables, or four with deemp, don't bother me. I want the ultimate in sound quality. In my player DAC combination I omit a lot of chips and a PLL using I2S direct. Guido is doing a great job constructing a FIFO. This is way over my head. I can only think out simple schematics... With the flip of a switch I can compare SPDIF with I2S direct. The switch is located as a two way for the I2S signals just prior to entering the DAC (TDA1543). In all honesty the CS8412 is not bad but you loose some quality. But I had to implement a lot of stuf for the CS8412: DIR with resetcircuit, AD8561, digital +/-5V supply, low noise +5V analog supply (for PLL). |
#36 |
Understood... I'm not denying yours is a better approach, but one of the purposes of my project here is to be compatible with any player with an SPDIF output.
I'm assuming you're using your Kwak clock inside the player though, to send the master clock to the main decoder chip on the player that outputs the I2S signals. Is this a false assumption? Whether or not you have a Non-OS DAC with my proposed setup, one would still benefit by the your low-jitter clock controlling the output of the CD decoder chip. Also, this would sync the player outputs that go to the SPDIF transmitter with the "reclocking" circuit on the outpboard DAC. This would complicate things too much for what I want to do, and as you say, one would be better off to just output the I2S signals individually. thanks Elso,
#37 | |
Banned
Yes of course I am using my own clock in the transport. In fact I still have the CS8412 in my DAC and normally I use the afore mentioned switch to choose between CD sound (I2S direct) and digital satellite tuner sound (SPDIF). It could also done with two 74HC125.
#38 | |
was a +-12V supply to use at dig IP board, so it was easy to bias a follower with simple R down to -supply. There was some level shifting required though which I did with a diode to get right DC level into receiver chip. However, you get the picture, class A discrete high speed circuitry works very well to buffer the receiver chip. Use your imagination, I can think of quite a few ways to do it. Cheers, Terry |
#39 | |
I copied the input side of the fifo, just the output side is changed. The FF is to start the read only when the fifo is half full. The 11.something MHz clock is connected to a divider and should go to a 7210/7310. The or gate there is for buffering. Just an example, i did not build this! logic types are just what i found quickest so use your favourite instead of hc(t). The output is NOT i2s, since the fifo goes to high impedance when read is high. The data and ws line go high then because of the resistors. Read is done on the high to low flank of clock/div4. Read in a tda1541/1543 dac is done on low to high. So at that moment data and ws are ok. According to the datasheet, the inputs need to be 0ns (1541) and 2ns (1543) stable after bck going high. The fifo goes to high impedance 5 ns after read going low to high. So that should be ok. If you want real i2s, use some ff's clocking low to high and invert the bck. Timing: bck = 2.8 MHz = 354 ns. Data needs to be ready at the dac 32 ns before bck goes low to high so the slowest (cheapest) fifo (65ns setup) should do. Just to show you an idea. GuidoB
GuidoB |
| Decoder output: how jittery, worth reclocking? And "double" reclocking | hollowman | Digital Source | 0 | 17th July 2009 01:39 PM |
| Ipod Line to SPDIF | mitchjs | Digital Source | 0 | 7th June 2006 11:23 PM |
| Reclocking SPDIF On M-Audio Transit | bryman79 | Digital Source | 0 | 30th April 2006 03:54 AM |
| Asyncronous reclocking of transport SPDIF output | Dr.H | Digital Source | 29 | 18th July 2005 08:39 PM |
| Reclocking data line | tonitze | Digital Source | 5 | 11th July 2003 04:20 PM |
| Page generated in 0.15495 seconds (84.15% PHP - 15.85% MySQL) with 11 queries |
