Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Low distortion, pure resistive I/V stage for Sabre Reference DAC
Old 7th November 2012, 08:34 AM   #51
roender is offline roender  Romania
roender's Avatar
SE analog output at 2Vrms (0dB digital), THD 20kHz
Old 8th November 2012, 04:56 PM   #52
staccatiss is offline staccatiss  Germany
I get -59 dB THD20k at 2Vrms output voltage which is about 20 dB worse than you get. I have tried the design with both your values for the 4V version, and also with my values. You vales give me only 3,6Vrms (balanced, 1.8Vrms single ended) using 16 mAACp-p signal input.
Not sure what the discrepancy is caused by.Might be the models.
Did you even consider making a DC coupled version by foloding down the entire schematic and making a complementary version?
/S
Old 8th January 2013, 10:47 AM   #53
roender's Avatar
Yes, I had done that but doesn't sound the same ... is more digital than analogic.
Old 24th March 2015, 02:04 PM   #54
CFT is online now CFT  United States
I understand your latest output stage has evolved into the one below.
ESS Sabre Reference DAC (8-channel)
So you now prefer it in voltage mode with higher output that gets filtered before going to a unity gain buffer while previously you had it in a sort of forced current mode then to a microphone preamp...
Could you describe the sonic differences? Is the filtering very important?
And would it be even neater to implement a common mode filter going into the buffers? Thanks roender.
Low distortion, pure resistive I/V stage for Sabre Reference DACHide this!Advertise here!
ESS Sabre Reference DAC VS Prism sound ADA-8XR, DAD AX24 and weiss DAC? mbl Digital Line Level 12 19th October 2009 09:48 AM
Copyright ©1999-2017 diyAudio
