Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Low distortion, pure resistive I/V stage for Sabre Reference DAC
Old 30th September 2012, 10:52 AM   #31
roender is offline roender  Romania
roender's Avatar
Schematic
Old 30th September 2012, 07:11 PM   #32
orelli is offline orelli  Italy
Send a message via AIM to orelli Send a message via MSN to orelli Send a message via Yahoo to orelli
I'm not experienced like you, but I think the resistor values depending from the Idss of Jfets and hfe of BJTs to give the current that you want. For example the 2.5mA that polarize J1 and J2 are feed by CCS formed by J6 and J7 and R16 and R17. Right?
And 2.5mA depending by Idss and resistor value.
What's the Vout RMS in balanced mode? Of course with BIII?
Thanks for the quick reply.
Best, Orazio
Old 1st October 2012, 06:26 AM   #33
roender's Avatar
You are correct in your assumptions related with biasing currents for CFP Njfet driver. In fact, you can choose jfets with 2.5mA idss and then not need any resistor for CCS current setting.
Vout[rms] = 650mV
Old 1st October 2012, 12:17 PM   #34
thank you very much.
Old 31st October 2012, 03:20 AM   #35
2A3SET is offline 2A3SET  Canada
How about raising the ground reference to AVCC/2 to be compliant?
Originally Posted by roender View Post
The offset voltage generated by the DAC do not mater. R14/19 are connected from the output of the DAC to ground.
This I/V stage can be seen as a microphone amplifier. The input resistor was increased to 2r2 in order to improve SNR to more than 125dB over 10-20kHz bandwidth. The Sabre Reference DAC is working now in "voltage mode" ... but is a voltage DAC anyway no mater what ESS is telling
Old 31st October 2012, 07:58 AM   #36
roender's Avatar
Would you please be more specific? Compliant with what?
What can be gained by rising the DAC output return to a steady potential of AVCC/2 than ground?
Old 2nd November 2012, 09:47 PM   #37
staccatiss is offline staccatiss  Germany
Nice IV converter!
I "hooked" it up in MicroCap10 Pro, and I have some issues with the lowish output voltage. It is ,when an ESS9018 is outputtting 16mA ACp-p + 8mA DC, only 0.4Vrms instead of the standardised 4 Vrms.
Do you also get 0,4Vrms at 0 dBFS?
/S
Schematic
Old 2nd November 2012, 09:48 PM   #38
Seems strange to me, too.
That would mean that the ESS9018 would not output any DC current (only AC current), right?
/S
Old 5th November 2012, 05:51 AM   #39
roender's Avatar
/S
I know what will happens if the output reference will be avcc/2, but is not clear what benefit will bring that.
Old 5th November 2012, 06:12 AM   #40
roender's Avatar
Nice IV converter!
/S
Nope ... should be around 600mV rms.
It is designed to be like that because my RMI-FC100 amp allow only 600mVpp at input for full output power.
Low distortion, pure resistive I/V stage for Sabre Reference DACHide this!Advertise here!
ESS Sabre Reference DAC VS Prism sound ADA-8XR, DAD AX24 and weiss DAC? mbl Digital Line Level 12 19th October 2009 10:48 AM
Copyright ©1999-2017 diyAudio
