diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Low distortion, pure resistive I/V stage for Sabre Reference DAC (http://www.diyaudio.com/forums/digital-source/218247-low-distortion-pure-resistive-stage-sabre-reference-dac.html)
roender 20th August 2012 12:45 PM
4 Attachment(s)
Is pleasing my ears now with very good micro-details, accurate mids and a phenomenal bass.
Enjoy!
Ken Newton 20th August 2012 01:17 PM
The 0.81 ohm indicated value of R6 and R9 must be an error, yes?
roender 20th August 2012 01:22 PM
Nope :-)
0.82ohm, 0.1% 5ppm/C ... I/V resistor ;-)
smms73 20th August 2012 04:28 PM
0.82 ohms are very low. Did you experiment with higher value?
I like the way you connect the bipolar and jfet. Did you experience stability problems ?
roender 20th August 2012 04:51 PM
Originally Posted by smms73 (http://www.diyaudio.com/forums/digital-source/218247-low-distortion-pure-resistive-stage-sabre-reference-dac-post3133672.html#post3133672)
Yes I did, but I perceived better sound by putting lower and lower I/V resistors. I had to stay at 0.81ohm value because there is no much gain in the circuit.
I have not find any stability problems until now.
roender 23rd August 2012 01:06 PM
125dB SNR
But most important, It sounds really good for a such simple I/V stage.
roender 24th August 2012 05:05 PM
1 Attachment(s)
Improved SNR and much lower distortion, mostly 3th at -114dB.
Was tested with square waves and didn't show any instabilities. :)
Zin = 1.8ohm
smms73 31st August 2012 05:49 PM
Very nice, I have a idea that uses that kind of connection but without the jfets , with only transistors, have you try using bjt in the place of jfets ? I get less distortion using bjt.
Joachim Gerhard 31st August 2012 05:54 PM
Is the output really loaded with a 1kOhm resistor ?
smms73 31st August 2012 06:23 PM
I have see this type of connection in Cordell book page 530. He call it jfet-bipolar CFPs.
Jochim this can be a good idea for you to try in your new MC amplifier. It has very low distortion and low impedance. I prefer with only bjt.
Resources saved on this page: MySQL 18.75%
