Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
The pcm1794a datasheet I/V converter and how to improve it.
Old 20th August 2012, 02:46 PM   #11
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by Ken Newton View Post
Three op-amps in parallel could reduce Johnson noise, but by no more than 9.5dB relative to a single such op-amp. However, you would need to isolate the low impedance output of each op-amp from that of the others with a resistor, so not the have them buck each other, which would increase distortion. Not what we want. Output isolation resistors will contribute their own Johnson noise, reducing that theoretical 9.5dB figure.
I was only half serious Ken. I also meant using one LME49600 in place of each of the buffers for three total in the entire circuit. I should try different emoticons to convey my silliness. This is supposed to be fun after all.
I'm surprised that the SK170 in source follower mode wasn't used for the buffer... everyone's favorite transistor! (I got an idea - an entire hifi made with nothing but SK170's! )
Old 20th August 2012, 02:47 PM   #12
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I think he means one LME49600 250mA buffer on the output of each op-amp; like in post #3 but IC's instead of discrete.
Old 20th August 2012, 02:47 PM   #13
smms73 is offline smms73  Portugal
smms73's Avatar
Lme49600 has a quiescent current of only 13 ma the buffers I use for u1 have 27ma. I think the lme will work in class b in this circuit because of the 6.2ma offset of the dac plus the 21ma swing.
Old 20th August 2012, 03:02 PM   #14
smms73's Avatar
Thanks for sharing your opinion about noise ken. but Unfortunately professional audio is a specs war , and wins the lowest noise. that's the reason the original circuit is so bad, with low resistors they have the low noise specs, and at 1khz the distortion seems tolerable . This is what the average consumer wants.
Old 20th August 2012, 03:29 PM   #15
dirkwright's Avatar
I thought this was DIY? what war?
Old 20th August 2012, 04:15 PM   #16
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
My mistake, dirk. I'm sometimes slow on the uptake.
On top of which my 9.5dB figure was wrong anyhow. The figure should have been around 4.7dB.
Old 23rd August 2012, 09:57 AM   #17
smms73's Avatar
This is an interesting topic
unfortunately not everybody thinks like you, i was hoping that more people would share their experience in using op amps and buffers.
SÚrgio Santos
Old 23rd August 2012, 12:18 PM   #18
dirkwright's Avatar
I don't have much of any experience so I have nothing to share, sorry.
Old 23rd August 2012, 01:11 PM   #19
zxgravediggerxz is offline zxgravediggerxz  United States
Not too long ago I started a topic on looking how to improve the PCM1794 I/V stage as well. It was looking into the op-amp implementation of the circuit by using different ICs.
http://www.diyaudio.com/forums/digit...om-needed.html
IC selection plays a big role as well in the circuit. I was focusing more on optimal IC selection at the I/V buffer stage because that's seems to be the weakest link to me.
I do lack the decades of experience of most on this forum but just by reading a bit on Johnson Noise (thermal noise of components?) it seems that it is relatively low and the IC and it's complementing component selection is key to great results.
Currently I have stopped my simulations (and DAC design) due to school and work but I plan continuing in the near future and coming up witth two new IC selections for the pcm1794 IV stage and a modifyable IV opamp stage so we can all experiment. Hope I can get to it sooner :/
This is not reality...
Old 23rd August 2012, 09:52 PM   #20
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
smms73, seeing your so handy at running sim's, could you do me a favour and run the sim on this, circuit.
As so far it has sounded so much better than anything I have ever heard, esspecially in dynamics from top to bottom, but what I have noticed is that it is very unkind to bad recordings, but if the recording is good it is very sweet sounding even with the massive dynamics it has.
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
The pcm1794a datasheet I/V converter and how to improve it.Hide this!Advertise here!
Comments on PCM1794A DAC design novec Digital Source 54 4th June 2012 07:58 PM
Micro DIR9001 + PCM1794A DAC theAnonymous1 Digital Source 88 14th June 2010 09:01 AM
FS: Twistedpear PCM1794A DAC Board pftrvlr Swap Meet 2 18th April 2010 03:52 PM
FS: 25pcs each PCM1794A and DIR9001 theAnonymous1 Swap Meet 1 5th December 2009 02:11 PM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 05:36 PM
Copyright ©1999-2017 diyAudio
