Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
The pcm1794a datasheet I/V converter and how to improve it.
Old 30th November 2012, 01:49 PM   #181
dirkwright is offline dirkwright  United States
dirkwright's Avatar
So, here's where I'm at now. I ordered some PCB's based on this circuit. They should be arriving today or tomorrow. There's nothing revolutionary about it. I added resistors to the + pins because it helps with DC balance, which lowers distortion in simulation. The AC voltage at the - pins is virtually nil even with these resistors. The four 1k resistors will be in a single DIP package for temperature stability. I hope it works well in real life.
Old 30th November 2012, 01:56 PM   #182
dirkwright's Avatar
Here's the component side of the PCB. I use Pad2Pad. Two ground planes, one on each side. The ground planes are used for shielding mostly, not for ground return currents. As suggested by an app note I read, the traces from the IC's to the bypass capacitors are huge. Also, in the data sheet for the BUF634, they suggest grounding the unused pins and soldering the IC directly to the board to help with heat dissipation. I've beefed up the thermal traces from those pins to the ground planes also in order to provide a good heat sink path. I also have some glue on aluminum heat sinks for these chips that I will use.
Old 30th November 2012, 06:27 PM   #183
Avro Arrow is offline Avro Arrow  Canada
Avro Arrow's Avatar
The only thing I can see is the thermal relief connections are very small.
I don't know how to increase the size in Pad2Pad. In Eagle it is in the properties
for the polygon command.
Old 30th November 2012, 06:32 PM   #184
dirkwright's Avatar
I increased them for the BUF634 grounded pins. It's entirely controllable in Pad2Pad. The LME49710 chips do not get warm so they don't need them really. Thanks for looking.
Old 30th November 2012, 06:43 PM   #185
Avro Arrow's Avatar
I am curious as to why you chose to combine both a ground plane and traces for your ground..? I'm not saying it is right or wrong, just unusual.
You might be interested in this article.
Old 30th November 2012, 06:53 PM   #186
dirkwright's Avatar
Do I have mixed signal chips on this board? I don't really know what that means. I assume it means both digital and analog chips on the same board? Thanks for the link.
There's no reason why I did the grounding this way. I do realize that most people use the ground plane as a ground return path. For me, it just worked out that way, mostly because I guess I didn't understand how it was normally done so I just invented my own way of making a ground plane. As it is now, the planes probably act more as a shield and heatsink than a ground return path. Maybe it's better that way, I don't know.
If I was doing a ground plane the "proper" way then of course those little connections between the through hole and the plane would be far more substantial. Since I already have ground return traces, I didn't bother making them fatter except where I knew there was going to be a lot of heat. I have the BUF634 strapped for high bias, so they get warm. Actually, too hot to keep my finger on them! (that's with them in a socket and no heat sink though, which is not the best way to use them)
Thanks for your interest and comments.
Old 30th November 2012, 07:14 PM   #187
Avro Arrow's Avatar
While "mixed signal" usually refers to digital and analogue signals, it can also refer
to low frequency and high frequencies. Seeing as your buffers can reproduce into
the hundreds of mHz, it is useful to think of this as a mixed signal board. Even if
you don't feed it high frequencies, undesired results may be obtained if you don't treat
the bypassing as if it was high frequency.
Cheers and good luck with your design!
Old 7th December 2012, 11:23 AM   #188
dirkwright's Avatar
I can report that my board does seem to work perfectly. I received them and all the parts this past week. I finally got around to testing it last night. Since I don't have a DAC running yet, I had to provide the balanced signal using an input transformer. In spite of that limitation, it looks like this has very good performance. The BUF634's got warm but not hot and they seemed to transmit heat into the ground planes just fine.
Old 7th December 2012, 09:08 PM   #189
smms73 is offline smms73  Portugal
smms73's Avatar
Congratulations, dirk.
SÚrgio Santos
Old 7th December 2012, 11:13 PM   #190
dirkwright's Avatar
Thanks. Hopefully everything will perform well once I have it in a box and got the DAC running. That's going to take a while yet.
The pcm1794a datasheet I/V converter and how to improve it.Hide this!Advertise here!
Comments on PCM1794A DAC design novec Digital Source 54 4th June 2012 07:58 PM
Micro DIR9001 + PCM1794A DAC theAnonymous1 Digital Source 88 14th June 2010 09:01 AM
FS: Twistedpear PCM1794A DAC Board pftrvlr Swap Meet 2 18th April 2010 03:52 PM
FS: 25pcs each PCM1794A and DIR9001 theAnonymous1 Swap Meet 1 5th December 2009 02:11 PM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 05:36 PM
Copyright ©1999-2017 diyAudio
