How to: 1.4v TCXO - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th August 2012, 02:12 PM   #1
cdfr is offline cdfr  United States
Default How to: 1.4v TCXO
I have a 3.3v 25Mhz ultra low jitter TCXO but I actually need 1.2 or 1.4v clock output.
I could not find 25Mhz TCXO operating at less than 3.3v.
I am currently using a couple of resitors to get 1.4v but the result is hardly satisfactory.
Does anybody know what I should use to lower the clock Vout?
Are there some IC that would preserve low jitter and do the job?
Old 19th August 2012, 08:10 AM   #2
marce is offline marce  United Kingdom
Level shifting IC will do the job.
Old 21st August 2012, 08:08 PM   #3
Thanks. Do you have any IC ref that would do the job and be ultra lowe jitter?
How about using a fast AOP (which)?
Old 22nd August 2012, 06:45 AM   #4
I know there are dedicated clock driver IC's for driving long lines, I would have thought they do a level shifting version, I'll have a look.
Old 25th August 2012, 05:14 PM   #5
I found the TI SN74AVCH1T45 which will take my 3.3v click signal and translate it to 1.2, 1.5 or 1.8v but the performance don' appear stellar (If I interpret correctly).
Switching characteristics, between 0.4 to 4.7ns.
The clock I use is a 25Mhz TCXO from Connor and windfield DF75F with 1pS jitter and 0.5ppm stability.
The shifter from TI is going to ruin the performance....
I use the clock to feed a Marvell processor in an audio server application.
Old 25th August 2012, 07:09 PM   #6
A series resistor and two diodes to the ground would not do the job?
Old 28th August 2012, 12:16 PM   #7
Somthing similar to this with level shifting
Non-PLL Buffers - Single Ended - CDCV304 - TI.com
Level Translators - Maxim
Currently no internet at home so sorry for the limited responce.
Old 28th August 2012, 09:23 PM   #8
Thanks Marce.
Yes may be the TI LMK00105 could do the job. i am going to read this in detail.
Getting 14.4v DJDestiny Power Supplies 78 7th May 2011 09:36 AM
Using 8.4V AC adaptor instead of 7.4V HouseMachine Parts 5 8th June 2006 01:44 PM
Tcxo XTAL Digital Source 21 17th May 2004 01:18 AM
Tcxo XTAL Parts 0 11th May 2004 09:21 AM
Where can I found TCXO? omar Digital Source 19 27th March 2003 09:52 PM
Copyright 1999-2017 diyAudio
