Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Ehm...basically just wanted a nice DAC..
Old 14th August 2012, 07:11 PM   #1
Olombo is offline Olombo  Germany
Default Ehm...basically just wanted a nice DAC..
Hey out there!
Ok I spent now days in internet and can not come to any decision. PLEASE help me!
I want 8 channel DAC as I drive all my speakers with active crossovers. Solutions which seems to be approbiate:
- Buffalo 3 (twistedpear) with USBStreamer (minidsp). Do I need 4 output i/v stages or are the chip outputs ok in you opinions?
- Get several Ebay-DAC. Connect on board with I2S and USBstreamer or use software JACK to just connect all 4 DAC seperately to pc and use the virtual sound card. I2S as long as the chip supports it I should be able to connect and just leave USB-section dead.
In Case of Ebay-DAC: WHICH???? I assume should be PCM1794 or WM8741. Unsure about the ak4393..
Some I found and look not too bad at first view:
HIFI DIY Tube USB DAC kit ,very good sounds .free shipping | eBay
DAC 2496 (AK4393)+CS8416+AK4393+5532 Kit | eBay
TE7022 WM8741 24Bit/96Khz USB DAC Decoder Digital To Analog Converter RCA output | eBay
NEW V1.9 DAC WM8741 WM8805 Coaxial Optical Decoder 24Bit assembled | eBay
Dual WM8741 DIR9001 input plus PCM2706 USB AD797 analog output ultimate DAC ! | eBay
Hi-END 24bit/192kHz PCM1794 +DIR9001+PCM2706 Coaxial USB DAC Decoder Assembled | eBay
Upsampling 24/192 DAC KIT with USB input,mainboard with PCM1794+DIR9001 | eBay
Assembled 24Bit/192KHz CS8416 + PCM1798 DAC & PSU board | eBay
and the last but also very interesting one:
Hi end USB CM6631+WM8805+4pcs WM8741 DAC kit LCM | eBay
So simple question: what is just best in your opinion!? I want to build this DAC ONE time for the next years....so if bit more or less expensive I do not really care just want be sure I am going to build something really good.
Thanks all!
Old 16th August 2012, 07:17 AM   #2
erin is offline erin  Australia
Your active crossover probably already has 8 analog outputs.
What is wrong with it?
If you are using the Behringer DCX2496 it already has modern AK4393 dac chips inside it.
you should be able to apply digital equalisation to balance the freqency response of your system in your room. All of the DAC kits you mention above use delta sigma DAC chips. Your crossover must allready have these. If you wanted to use older R2R / multibit DAC chips I can understand but, really you would just be adding extra complexity to your system and another "thing" in the signal path and I don't personally think there would be any advantage to doing what you suggest.
I think it would be better for you to suggest what you dont like about your sound and ask for suggestions how to "fix" your sound.
Old 16th August 2012, 09:28 AM   #3
my active crossover is in PC with FIR filtering software. So I have nothing at the moment what is fitting. Usual sound card outputs is not what we deserve or? ;-)
Old 17th August 2012, 12:08 AM   #4
How did you intend to get 4 SPDIF signals out of the PC to the DAC?
A soundcard with ADAT?
Ehm...basically just wanted a nice DAC..Hide this!Advertise here!
Symasym and RF noise (?)... Ehm... Need help... Porfido Solid State 15 22nd October 2011 10:33 PM
A nice dac to complement the Aleph-X. LBHajdu Pass Labs 104 19th September 2011 12:30 PM
Are they basically Borbely hybrid circuitry? Tubenstein Tubes / Valves 0 19th August 2011 10:06 AM
Rotel RC995 vs Adcom 565-Which is better sounding overall? Are they basically equal? dtm1962 Solid State 1 31st July 2006 08:54 AM
TDA 1545 , a nice sounding dac? setmenu Digital Source 2 30th September 2004 12:25 PM
Copyright ©1999-2017 diyAudio
