CM6631 usb audio interface .... any good ? - Page 34 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th May 2013, 01:10 PM   #331
Originally Posted by wklie View Post
Which firmware is your card running?
originaly it comes with ver 0107. now it flashed with one of the oem fw taken from this thread and this is the reason why i searching for original fw because now no sound from all outs
Old 9th May 2013, 05:12 PM   #332
wklie is offline wklie  Hong Kong
I don't see Asus posting firmware for ROG Thunderbolt Audio/LAN combo card. However, if you can get the Asus Xonar Essence One firmware 0109 or 0111 to flash on your card, I think there's a chance it may work.
Old 9th May 2013, 07:12 PM   #333
already tried Essence One firmwares. still no sound
Old 10th May 2013, 03:51 AM   #334
After flashing the Asus firmware, have you reinstalled the Asus drivers? And try both the Thunderbolt Combo driver and the Xonar Essence One driver.
Old 10th May 2013, 09:41 AM   #335
of course
Old 13th May 2013, 11:09 PM   #336
I have just received an CM6631A. I have installed a driver on my windows 7 laptop and I have no problem.However, on my MAC mini running Mountain Lion, I canīt get it to work at all. I use Audirvana and the JRiver beta for MAC, but it do not work with any o them. What is the problem. I have not a clue.
Old 14th May 2013, 02:41 AM   #337
Several things to try:
- Read http://emotiva.com/resources/media/x...le_Drivers.pdf
- Connect the CM6631A to your Mac before powering up the Mac.
- Try each and every USB port.
- If you have an external power source for the CM6631A device, use it.
- On page 29 post #284 bvs has discovered a solution for Mac compatibility by removing a reset chip from the device.
Old 14th May 2013, 05:50 AM   #338
hewball is offline hewball  Australia
Perhaps this is not what you're asking, but anyway, the data sheet states that it can do I2S input and I2S output.
i noticed some datasheets having the I2S input greyed out, so hence my question of does anyone know of it working, or know which device currently sold has a chip to support this
Hewball
Old 14th May 2013, 10:21 AM   #339
I have an external power supply, but I have not been able to figure out what voltage the CM6631A needs/takes. I donīt want to toast it.
The strange thing is that others that have been reporting problems can play 16/44,1 files without problem, but I canīt play 16/44,1 either.
Old 14th May 2013, 06:07 PM   #340
DC 5V
USB Audio Interface oodi Digital Source 6 30th December 2011 08:59 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 03:58 AM
Recommendation on good USB-SPDIF interface? kop89 Digital Source 13 2nd August 2008 08:51 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 08:48 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 11:24 PM
Copyright Đ1999-2017 diyAudio
