dac I/V convertion with very low distortion - Page 81 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd February 2013, 06:24 AM   #801
Joachim Gerhard's Avatar
You just invented the series capaciantance bridge.
Old 3rd February 2013, 06:34 AM   #802
smms73 is offline smms73  Portugal
smms73's Avatar
Originally Posted by smms73 View Post
Is simpler to improve the input stage to make it immune to voltage variation in the rail , is better to leave the ccs cascoded by the output stage. Believe-me .
Or... not believe . in simulation it seems there is nothing to gain in cascoded the ccs with the output stage, but with measurements in the prototype it was better, i have to take a better look.
Sérgio Santos
Old 3rd February 2013, 10:35 AM   #803
MiiB is online now MiiB  Denmark
The CCS can also be bettered by inserting a Jfet CCS instead of the two 10 K.ohm resistors, then you take the influence from Rail variations out.
I like the scaling by inserting more current-summing legs, as apposed to unbalancing the mirror.
Casodede mirrors are more than 10 fold higher in impedance and with the beta helper you can get really High.
Old 3rd February 2013, 02:46 PM   #804
smms73's Avatar
Originally Posted by keantoken View Post
Also, your cross-connected Baxandall type VAS is good but I compared it to the traditional complimentary Common-base Baxandall VAS and it has inferior PSRR. Have you tried Edmond's arrangement in figure 5 here?
I have now simulate the two circuits. And i also get just a little beter PSRR with the baxandall pair but its a minor difference, and i have better distortion figures with my type of connection also a minor diference. Both get good behavior with a square wave input.
I do not care to much about PSRR because the power supply that i use have already very low noise, it is similar to your The K Multiplier
In the begining i use only capacitance multiplier, with very low noise also but using a cfp gives a lower output impedance, there is very low A.C. current in the power supply rails, so the output impedance of the power supply is not that important.
The first picture are the output noise of a 7815 regulator , second the noise at the output of the cfp capacitance multiplier.
The third picture is the measurement of distortion of the real circuit with a input impedance of 3k 8ma p-p and 2v rms out (is the same as the sound card i use) .
Sérgio Santos
Old 3rd February 2013, 03:09 PM   #805
smms73's Avatar
Yes using a jfet ccs will be better, the resistors were used for the dc servo . The variations in Vce of the ccs transistor will make variations in the base current , so for take the influence from Rail variations out, you have to insure that the Vce from this transistor is stable, one way is cascode it with a fet or mosfet.
Sérgio Santos
Old 3rd February 2013, 03:23 PM   #806
smms73's Avatar
This is a preamplifier with the same principles that we are talking here, it has a gain of 16x with 250 ohms in R2 if you want lower gain you have to increase this resistor 500 ohms for a gain of 8x and 1k for a gain of 4x. the maximum voltage out is 16 volts p-p.
I have post it here with other 2 for my one and there are also some circuits design by Dado and keantoken, I recomend that you take a look.
Current conveyor as a voltage amplifier
The distortion is 0.000069% at 4 V p-p with a gain of 16x
This is a basic circuit and can be improve further , It also needs a output buffer to lower the impedance , but that is another story.
Sérgio Santos
Old 3rd February 2013, 04:02 PM   #807
smms73's Avatar
As I understand you referenced the drivers to the rail to effectively cascode the CCS. However this leaves the input stage open to rail variations. If you decouple R15 with a lytic and delete R10/R24 decoupling, and then improve the CCS, you will lave less overall Iq modulation which I think will result in more PSRR.
You are right Kean , is better to have the voltage reference to ground, Thanks very much for the tip .
Joachim have already advice for that matter some time ago. And at that time i did not see it . I will make that change.
Sérgio Santos
Old 3rd February 2013, 07:05 PM   #808
If you use a cascoded JFet current source It's possible to inject the servo-current between the two JFets, the you get both high impedance and Servo adjustment.
Line stage looks really good, open-loop and with the possibility of an truly non degrading volume-control...
Old 3rd February 2013, 11:45 PM   #809
keantoken's Avatar
To lower output impedance could you rework the input to accept feedback? After all there is a lot of spare gain if you remove R2. Perhaps you could do a compromise and have say 100R output impedance.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 5th February 2013, 10:43 PM   #810
smms73's Avatar
kean using a global feedback loop is a possibility , but I will not go that way , at least not now.
Instead i present a simple buffer that uses a complementar feedback pair , I know much of people in this forum don´t like cfp , but i found it very interesting .
I think that much of the bad reputation that cfp has, is because people do not use a mean to prevent oscilations that can occur in some situations.
In a not so long time ago i expriment a I/V converter with a differential cfp pair and when i was measure distortion , some times a little oscillation of high frequency occurred, but as all of the circuits that i had seen with cfp do not has any mean of oscillation prevention, i did not use any also , inserting a capacitor C1 like in this pictures is very effective in stabilize the cfp loop, that sollution work very well .
Sérgio Santos
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 02:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 05:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 01:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 01:40 PM
Copyright ©1999-2017 diyAudio
