Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th December 2012, 10:22 PM   #721
smms73 is offline smms73  Portugal
smms73's Avatar
files of the TAGUS project.
Sérgio Santos
Old 5th December 2012, 10:32 PM   #722
Joachim Gerhard's Avatar
Well, i am confused, U2 is connected to V1, V2.
Old 5th December 2012, 10:51 PM   #723
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
Originally Posted by smms73 View Post
last week i visited a audio show with a lot of high end products, and that make me want to build an amplifier without feedback, and i am already testing some ideas to attain that. so a I/V converter design exclusively for ess9018 is not a priority right now.
But i have modified the pcb like i said in prior post, to use this I/V with the ess9018, but each pcb can only be connected to 2 dacs from ess9018 maximum, the ideal is one I/V pcb for each of the 8 dacs.
The output of the I/V converter boards will be paralleled, and only one servo and one buffer per channel will be needed the others 3 or 7 tagus pcb will run in slave and dont need the servo or the output buffer. I will post the connection schema for this.
In resume: is possible to use this pcb for the ess9018 , but we need at least 4 pcb per channel running in parallel. The ideal is 8 pcb per channel.
so this makes it not possible to use es9012? is it the current thats an issue?
edit, I see why, too low output impedance with the dacs in parallel, so yes it does seem that 9012 will be a problem.
oh well, I didnt actually NEED to build another IV convertor anyway, they just fascinate me
Old 5th December 2012, 11:40 PM   #724
smms73's Avatar
it is possible to use ess9012. there is no problem.
Sérgio Santos
Old 5th December 2012, 11:46 PM   #725
smms73's Avatar
u2, v1, v2 forms a variable power supply for u1( class a)
v1 and v2 are floating power supplys, you can imagine that they are batteries.
Sérgio Santos
Old 6th December 2012, 12:06 AM   #726
qusp's Avatar
hmm but you say its preferred to run 1 x IV for each dac, or pair of dacs, because of the low impedance output of the dac current source. there is no way to separate out the dacs with the 9012, so you are stuck with the equivalent of running 9018 in stereo mode
Old 6th December 2012, 12:15 AM   #727
smms73's Avatar
Qusp what is the output impedance of ess9012? I was thinking it was in the 700 ohms region.
You can parallel also the input of the tagus to bring down the input impedance of the i/v converter.
Sérgio Santos
Old 6th December 2012, 12:49 AM   #728
qusp's Avatar
no, thats the output impedance for a single DAC channel in the es9018 ie ~780ohms with ~3.9mA p2p current and ~3.05V pp (with standard datasheet operating voltages, some like myself like to run AVCC at 3.5-3.6vdc instead of 3.3vdc) both es9018 in stereo mode, or es9012 in stereo mode are the same ~195ohms outputZ and ~15.6mA. 9018 in stereo and 9012 in stereo are basically identical
that rules out the use of some devices, so paralleling is needed for more than just impedance depending on which are used ie. K170 is no use unless you have a sneaky stash of K170V. this is why K369V is used in Patrick's SEN for ES901X
Old 6th December 2012, 04:34 AM   #729
smms73's Avatar
thanks for the correction qusp.
with that value of impedance and current output, using 4 parallel pcb per channel will be a good soluction. tomorrow i will post the schematic of the connections for running tagus in parallel.
Sérgio Santos
Old 6th December 2012, 06:02 AM   #730
qusp's Avatar
no problem, look forward to it. I suppose all efforts would need to be made to keep traces/wires the same length to avoid smearing?
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2013 diyAudio
