Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th November 2012, 08:52 AM   #681
smms73 is offline smms73  Portugal
smms73's Avatar
Originally Posted by georgehifi View Post
Why not have the board with a jumper bypass option and no buffer components installed for those that don't need it?
Cheers George
Adding the space in pcb for the buffer will increase the PcB cost in 50%, I want this circuit to be high quality but also accessible , but I agree that including the buffer has benefits. So it will be added a modified diamond buffer that have a linearity suitable for this project (less than 0.0001% distortion) without feedback loop. buffer will be in a auxiliary PcB that can be connected in the main pcb. this way the main PcB will be more accessible and we can experiment with others buffer like the one that Joachim and MiiB present that is also a very good solution.
Sérgio Santos
Old 17th November 2012, 09:28 AM   #682
merlin el mago's Avatar
I would like it included, as you can imagine myself and my customers are driving into a low impedance Lightspeed Attenuator. Why not have the board with a jumper bypass option and no buffer components installed for those that don't need it?
Cheers George
Originally Posted by Telstar View Post
I would like the buffer on the same pcb but draw in a way that it can be omitted just not soldering the components there (so kind of double output point). Simple enough? If alex_mm will do the pcb should be easy cake for him.
+1
Old 17th November 2012, 11:25 AM   #683
Telstar is offline Telstar  Italy
Originally Posted by smms73 View Post
Telstar, I will be the one that makes the pcb.
I didnt mean to diminish your skills, sorry.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 17th November 2012, 03:11 PM   #684
smms73's Avatar
No problem Telstar. I just wake up with bad humor.
Sérgio Santos
Old 18th November 2012, 06:34 PM   #685
regal is offline regal  United States
Originally Posted by zenelectro View Post
It doesn't matter where you connect the servo, it is -always- in the audio
path. Over the years this discussion has come up repeatedly.
The servo has to adjust the -audio- OP DC level and do so by integrating
the audio itself. Every servo works this way, you can connect them wherever
you like but if they are to work, they are in the audio path.
As such they definitely are audible and can often sound worse than a good
coupling cap. I know people who have in fact gone to extreme lengths to
make the servo truly out of the circuit, one worked on heat feedback and
another was a sampling system which made small adjustments at pre defined
time intervals, otherwise being off.
Just socket the opamp and try swapping it - you might get a surpise
George,
The optimum value of the LPF cap will probably be system / DAC dependent.
You might even get away without one, if the I-V is stable as such. The
1704 has low OOB noise.
WRT the 2k OP resistor, I would first try this I-V without an OP buffer.
It may well sound better 'in the raw' so to speak.
The issue with OP buffers is you will be hard pressed to find a design that
preserves the linearity of this I-V's super low distortion.
It will almost certainly require some sort of bootstrapping.
I agree that the servo will always be in the audio path just as the power supply is. There is a trick to simulate the dB level of the servo vs frequency. Its not uncommon to find that an an open loop I/V design with a servo has significant feedback up to midbass . There is a model posted on this forum somehwere. May want to have the option to go sans servo and use a cap.
As far as a buffer, I guess I always think of a buffer following an I/V as an opportunity to make a nice filter in between. Its good that you are planning a separate buffer panel so folks have that option.
This is great stuff. Thanks for sharing.
Old 18th November 2012, 07:08 PM   #686
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
you know that 2nd harmonic buffer is a very cool idea that I would love to have a lash at. why oh why did you have to come along with another IV I want to build?
Old 21st November 2012, 10:06 PM   #687
smms73's Avatar
qusp, I do not know any device that only produce 2° harmonic, the buffer that I was talking also product 3° harmonic but at 33 db lower level. if one has careful the third will be bellow noise floor. It is only a mosfet BS170 in single end with a ccs of 15ma and a load of 1k ohm, I have choose BS170 because it produce 10 time more distortion than a bjt.
Sérgio Santos
Old 21st November 2012, 10:27 PM   #688
smms73's Avatar
Regal, If I understand what you are telling , you say that if a opamp has 110 DB of open loop gain for example , the filter should have at least 110db of attenuation at audio frequencies ? I will investigate this. I will see if I have time to simulate the frequency response of the servo.
Sérgio Santos
Old 21st November 2012, 10:36 PM   #689
smms73's Avatar
I have almost finish the pcb, tomorrow I will post some 3D images of the board, the dimensions are 80mm x 90mm.
Sérgio Santos
Old 22nd November 2012, 09:46 AM   #690
smms73's Avatar
I have made some simulations to see the frequency response of the servo, and some alterations to prevent the servo from having feedback at audio frequencies.
The first image is the open loop of opa2134 , the second is the FR before the modifications, third is FR with modifications, the last is the modifications in R25 and C18.
with the modification the servo does not have excess gain to have feedback above 40hz , if we decrease R25 to 200ohms this value decrease to 20hz.
in second image in green there is th FR of the servo with only one pole, in this way the servo has excess gain to have feedback until 1000 Hz , with two pole servo this value is much lower (blue).
Sérgio Santos
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2013 diyAudio
