dac I/V convertion with very low distortion - Page 68 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th November 2012, 11:08 AM   #671
I was thinking about noise and not PSRR per se. The regs you use are relatively noisy, and my question was how much total RMS uV noise they have in a given BW, say 20 - 20kHz. My concern is that a IV converter of your caliber need a super low noise PS.
/S
Originally Posted by smms73 View Post
To measure power supply rejection ratio one inject a signal in the power rail , then measure the amplitude at the rails and then in output, the psrr is the difference between the two . I have already done that and post the results somewhere in this thread, if I remember it is 80db at 50 Hz .
That buffer that I present is intend to distort , is not to be use in this project. Is for a test that I am preparing, to understand the influence of harmonics in the sound , more of a psychoacoustics test.
Just by looking to the fft graph you can see that the buffer is in class a , class b produce lots of high order harmonics.
If you take a good look to the tagus schematic you will find a suitable buffer .
Old 16th November 2012, 12:55 PM   #672
smms73 is offline smms73  Portugal
smms73's Avatar
In post #662 I only post the noise of a power supply based on 7915/7815 for comparation i will not use that power supply .
The noise measurements from the power supply that I am going to use are the second and third images , the noise is really very low (I was surprised by such a low noise)
basically is the same as the emu1212m .
Or as you say a super low noise PS.
Edit: I use this type of power supply for a long time but this was the first time I test them. I will post a schematic of it , when I have finish all the alterations that I want to do.
Sérgio Santos
Old 16th November 2012, 02:42 PM   #673
smms73's Avatar
/S
The 0 dbfs of emu1212m is 2 Vrms so looking at the graphic we see the hight noise is at 20Hz is -127 db and that is 950nV rms, at 1Khz is 120nV rms.
Sérgio Santos
Old 16th November 2012, 03:27 PM   #674
OK, then it is only to integrate the squares of all voltage levels between 20-20kHz and then take the sqaure root of that integral (sum) to get the total noise 20-20kHz....I thought that the software could do that but maybe Arta cannot.
BTW, the caps are correct across the constant current diodes and the caps are not for stability.
/S
Old 16th November 2012, 03:37 PM   #675
dirkwright's Avatar
Yesterday I have been working in the power supply for this circuit.
First is the power supply based on 7915/7815, second is the modifications at the power supply, as you can see the noise and ripple is extremly low, and almost the noise floor of the EMU1212m.
One tip: Use ferrite beads in your power supply, there are some high frequency spikes that only ferrite beads can supress.
first 7915 , second positive w/mod, last negative w/mod.
measurements made in the power rails , with 40ma load.
So, you recommend ferrite beads between the regulator and the circuit to reduce noise? I should try this, thanks. I can see the noise from the 7815/7915 in my power supplies on my scope, but wasn't sure what to do about it.
Old 16th November 2012, 06:40 PM   #676
MiiB is offline MiiB  Denmark
The circuit has rather high(ish) PSU noise suppression, as it's fed by current sources from both rails..and there's an option to add a large(ish) cap between the current rails.
Old 16th November 2012, 07:35 PM   #677
smms73's Avatar
I have a good solution for the buffer, i am working on the circuit, and it will have to be tested,
do you guys think that the pcb should have a buffer in it. or the buffer should be in another board so we can try different buffers?
For me personally , i think i will not need the buffer on the pcb.
Sérgio Santos
Old 16th November 2012, 07:54 PM   #678
georgehifi's Avatar
Send a message via MSN to georgehifi
I would like it included, as you can imagine myself and my customers are driving into a low impedance Lightspeed Attenuator. Why not have the board with a jumper bypass option and no buffer components installed for those that don't need it?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 16th November 2012, 10:08 PM   #679
Telstar is offline Telstar  Italy
I would like the buffer on the same pcb but draw in a way that it can be omitted just not soldering the components there (so kind of double output point). Simple enough? If alex_mm will do the pcb should be easy cake for him.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 17th November 2012, 08:16 AM   #680
smms73's Avatar
Telstar, I will be the one that makes the pcb.
This is my contribution to the diy community.
Everyone can make a pcb for personal use. please, just do not sell it.
These last note is not for anyone in particular.
Sérgio Santos
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
