dac I/V convertion with very low distortion - Page 65 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th November 2012, 01:36 PM   #641
MiiB is offline MiiB  Denmark
The servo is connected to the negative input of the Fet opamp...In LT spice it nulls the offset...
Old 14th November 2012, 01:40 PM   #642
zenelectro's Avatar
Miib, the servo you have shown is wrong polarity - needs inverting. This is for sure.
Old 14th November 2012, 02:04 PM   #643
somethings funny...or a little weird... regardless of the connection the modeled servo nulls the offset. If I remove it the offset is 60 mV... hmm
Old 14th November 2012, 03:09 PM   #644
smms73 is offline smms73  Portugal
smms73's Avatar
In the design of that buffer have you guys think about adding a battery to the gate of the upper jfet, with less than 1nA of leakage current a litio battery will last forever. And the voltage of source to drain of the lower jfet will be higher .
I like the BF862
Sérgio Santos
Old 15th November 2012, 06:51 AM   #645
I agree that the voltage is too low across drain source. What I do instead, but that takes a few more components, is to use a Zener diode with LP filter, and then a transistor. You can then set VDS to what you prefer.
/S
I like the BF862
Old 15th November 2012, 07:32 AM   #646
What is the benefit of a higher VDS..?? and Why would you want to create a fixed Cascode..?? then the voltage swing would still have to throw charge so the capacitance comes into play.
Old 15th November 2012, 07:46 AM   #647
Joachim Gerhard's Avatar
In praxis our buffer works very well although the output transistor has only Vgs of the cascode transistor from drain to source.
Old 15th November 2012, 09:13 AM   #648
I Agree.. this is the most transparent buffer I have ever tried...just an impedance converter, to me as transparent as a piece of wire.
Old 15th November 2012, 01:21 PM   #649
Well, to have a fixed VDS is the point
Reasons for higher VDS than VDS = Vp:
1) I can have a VDS that makes the semiconductor sounds best
2) Use a VDS where the JFET is most linear
3) Higher VDS means lower capacitances
Attached are two different ways to cascode for higher than VDS = Vp.
Old 15th November 2012, 01:38 PM   #650
Our design is a driven, floating cascode, your design is a fixed cascode, parallel symmetric.
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
