dac I/V convertion with very low distortion - Page 64 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th November 2012, 08:58 AM   #631
MiiB is offline MiiB  Denmark
The problem is not in that direction, the problem is the varying gain when we see different impedances in the equipment the DAC is attached to..there you may look into into something with a quite lowish impedance.
I know the current conveyor has no problem with a short, as the output is a current source.
Old 14th November 2012, 09:32 AM   #632
Shinja is offline Shinja  Japan
smms,
I realized that we need to take care the input impedance next to your circuit.
e.g. SEPP JFET buffer or voltage follower with JFET opamp have high input "resistance" ,but large capacitance.
when the capacitance varies by input signal voltage, the actual IV impedance will vary and cause distortion.
Old 14th November 2012, 09:58 AM   #633
Joachim Gerhard's Avatar
PO6S-LOG 1,0K - Drehpoti. logarithmisch, 6mm, stereo 1,0 k-Ohm bei reichelt elektronik
This ones sound very good and they are cost effective. I think they are conductive plastic.
Old 14th November 2012, 11:22 AM   #634
smms73 is offline smms73  Portugal
smms73's Avatar
Sorry MiiB, my mistake, I understand now.
Thanks Joachim, I will check that.
Shinja I think we can use a cascode that keep the source drain voltage constant, that will remedy the problem , for now I want to concentrate on the pcb, but please see if you can arrange some good buffer and post your ideas.
Sérgio Santos
Old 14th November 2012, 11:42 AM   #635
This here could be a very good solution...for a complete circuit...Gain and offset set for the PCM1794
/M
Old 14th November 2012, 11:52 AM   #636
smms73's Avatar
MiiB, good work with the buffers, thats the kind of thing i talk, in last post, i will check it better later. I think you have the polarity of the servo inverted, but i will check it later
Sérgio Santos
Old 14th November 2012, 11:57 AM   #637
Polarity is correct.. It works and has nanovolt offset... the buffer in itself has -140dB distortion ans is not visible on the FFT. We have used this buffer in the Paradise, where we have seen it work very very good.. Its easy to implement and requires no selection.
Old 14th November 2012, 12:55 PM   #638
Telstar is offline Telstar  Italy
Originally Posted by zenelectro View Post
It doesn't matter where you connect the servo, it is -always- in the audio
path. Over the years this discussion has come up repeatedly.
The servo has to adjust the -audio- OP DC level and do so by integrating
the audio itself. Every servo works this way, you can connect them wherever
you like but if they are to work, they are in the audio path.
As such they definitely are audible and can often sound worse than a good
coupling cap.
Therefore you also believe that the whole psu is in the audio path.
I don't have much experience on servos, but the switch that Segio is preparing will allow us to try with and without it.
The optimum value of the LPF cap will probably be system / DAC dependent.
You might even get away without one, if the I-V is stable as such. The
1704 has low OOB noise.
WRT the 2k OP resistor, I would first try this I-V without an OP buffer.
It may well sound better 'in the raw' so to speak.
Absolutely. The analog lp filter has a very detrimental effect on sound, at least on 1704 and 1541 where I have always preferred the dac filterless. This is the beauty of multibit dacs- they don't *require* oob filtering.
Same thing for buffers- the b1 is NOT transparent. I'm still looking for one that truly is.
Another requirement of a good I/v is speed (phase linearity at hf), even some modern opamps fare well in this regard. I think that this circuit is very promising WRT.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 14th November 2012, 01:10 PM   #639
Are you absolutely certain the servo polarity is correct? It appears reversed to me as well.
Ken
Old 14th November 2012, 01:32 PM   #640
zenelectro's Avatar
No. The PS rejection and servo are completely different issues.
You have to think about this a bit more - eventually you will see it.
Yes that will be a good exercise.
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
