| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#601 | ||
I personally prefer open loop circuits but between one with 1% thd@1W and another with 0.01% with closed loop, I prefer the sound of the latter.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#602 |
Here you can test your ability to hear distortion :Listening Test
I scored in the middle ground.Even 1% low order distortion was hard for me to differentiate. 0.1% low order is definitely not audible. If you can you are an alien. |
#603 |
Here is an older test on how much distortion we can hear :http://www.linearaudio.nl/Miscellane...0recorders.pdf
The test subject was non other then Les Paul. |
#604 |
Designing for ultra low distortion is not hard anyway :http://www.linearaudio.nl/Documents/...ralization.pdf
problem solved !? |
#605 |
Problem with speakers is that the distortion you measure is steadystate....so you don't even count the Doppler distortion from multi-tone and the fact that magnet systems are very very nonlinear so a 2kHz on top of a 100 Hz may look quite odd.
On a smaller product like a preamp...distortion may be ca. valid measure, as we have somewhat control of impedance's in both ends. But in the thread where you nailed my quote we were talking amplifiers driving speaker loads, and in that respect Distortion is a non measure. Or it says nothing about sonic qualities of the circuit. |
#606 | |
#607 |
I like low distortion too. If it sounds good all the better. I find it just so sad that amp designers do not talk much to speaker designers. I think we should take the interface problems more serious.
#608 |
I second that...speakers and AMP interfacing is a key issue, how does an amplifier deal wit return-currents, how does it bleed back through the feedback.. ect ect.
And I must correct myself, your quote was indeed taken from this thread, but was pro or con an opamp circuit vs an simple discrete solution. where i preferred the simple in-spite of an on paper poorer performance. (sorry) |
#609 |
Some work has being done :http://www.cordellaudio.com/papers/i...distortion.pdf
But what is a "proper" design ? |
#610 |
I know this is not the proper place for it.... and it should have it own thread... bu to be honest the speaker model in Cordells paper is as good as none...
The hardship is including the nonlinear mechanics in the model. It's mainly the masses that creates the Back EMF that the amplifier has to deal-with..currents out of phase with the driving Voltage... I think there's one of the big differences in VFB vs CFB...sorry.. again not to change the thread, but merely a point of view worthy of concentration. |
| ultra low noise low distortion preamplifier needed | neazoi | Solid State | 13 | 11th October 2011 01:03 PM |
| IRF610 I/V convertion from Pass Labs D1 dac - single ended | schiller | Digital Line Level | 5 | 15th October 2009 04:33 PM |
| Distortion+low volume.. | GeirW | Tubes / Valves | 5 | 25th November 2004 12:04 PM |
| Best low-noise low-distortion buffer? | borges | Solid State | 7 | 9th December 2003 12:40 PM |
