| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#581 |
This is the bipolar input version, some resistors value may yet be changed (R13,14,20,21). Final version only when pcb is finished.
edit:Q10,13,12,3 are bc550c , bc560c
Sérgio Santos |
#582 |
I like the servo. This is really cool.
#583 |
I think the whole thing is really cool! I'm looking forward to trying this one day and listening to the difference between the BJT and JFET input devices. Keep it coming Sérgio!
#584 |
Joachim tanks for your kind words and the incentive that you always give me, it means much to me , as i also admire your work in SONICS , i realy like the design of your speakers specialy the SONICS Anima, its a very beautiful speaker.
bkdog, it is almost done .
Sérgio Santos Last edited by smms73; 8th November 2012 at 03:07 PM. |
#585 | |
Does it have a low pass filter in the first stage ?
RC |
#587 |
I didn´t know that you leave sonics i have to check Canalis.
RCruz, Yes it has a low pass filter. This is a convencional inverting integrator followed by a inverter to give the polarity that we need. If you look at post #553 , there are two servos , they both do the same thing but the first with the dual opamp will only use one capacitor, so we save the costs of the capacitor and the pcb space (that also have costs), so the choice of this type of servo is just a economic one. The difference in this implementation is that normaly you see DC servos connected to input of the amplifiers and the noise of the servo opamp will be injected in the main amplifier, so you need to use a audio grade opamp for low noise like opa627 , but in this case the servo is not in the audio path (as Ken Newton has explain in post#561) so you just need to use a opamp with low input offset , the noise is not important (like for exemple max4238 less than 1€ and much beter in dc precision than audio opamps). This is more economical (opa627 cost more than 20€) and better sonically as the servo is not in the audio path. edit: Bob Cordell in his book "Designing Audio Power Amplifiers" has a chapter about servos , i recomend you people to buy this book.
Sérgio Santos Last edited by smms73; 8th November 2012 at 07:25 PM. |
#588 |
Ricardo... this servo implementation is exactly the same as the one I used in the Paradise, so at one point it should be familiar to you, here Sergio is really smart as he uses the Diodes of the transistor to create CCS's, that also has the capability to mirror in the cervo current in and add and subtract in on the drive current and thus push the output to 0. this is simpler and smarter....clever
In the paradise we had some debate on the use of a servo, but there and here the influence on the audio path is non existent. Last edited by MiiB; 8th November 2012 at 07:38 PM. |
#590 |
In the Paradise We only use one pole and one opamp.
| ultra low noise low distortion preamplifier needed | neazoi | Solid State | 13 | 11th October 2011 01:03 PM |
| IRF610 I/V convertion from Pass Labs D1 dac - single ended | schiller | Digital Line Level | 5 | 15th October 2009 04:33 PM |
| Distortion+low volume.. | GeirW | Tubes / Valves | 5 | 25th November 2004 12:04 PM |
| Best low-noise low-distortion buffer? | borges | Solid State | 7 | 9th December 2003 12:40 PM |
