dac I/V convertion with very low distortion - Page 54 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th October 2012, 02:33 PM   #531
Joachim Gerhard's Avatar
Have you tried to shunt R15 ?
Old 30th October 2012, 03:01 PM   #532
smms73 is offline smms73  Portugal
smms73's Avatar
Originally Posted by MiiB View Post
Thanks.... I think, a good solution... if you make a cascoded Jfet CCS. you have Tera-Ohm impedance for the first more than 100 KHz then dropping with the capacitance of the cascode Jfet. but never lower than a couple of hundred Kohms.
MiiB Jfet CCS are the simplest solution for making a CCS but the jfet parameters are not very accurate. but is a possibility.
im sorry but Tera-Ohm impedance is not possible. even 1pf of parasitic capacitance would bring it down even at 1Hz. The cascode serves to stabilize the voltage across the ccs, but in this case is not necessary as the input voltage is 9mv rms maximum.
Have you already read the paper about ccs that ken newton post ? if not read it , there is a lot of good information.
Sérgio Santos
Old 30th October 2012, 06:37 PM   #533
MiiB is offline MiiB  Denmark
You may be right..., however my LT simulator says different.... I wonder if the models aren't sufficient even to calculate CCS impedance.... hmmm So much for for believing that..
Old 30th October 2012, 06:51 PM   #534
Avro Arrow's Avatar
Default CCS Performance
I did some sims of various CCSs a while ago.
Here are some of the results.
Schematic followed by graphs.
First, LED based:
Old 30th October 2012, 06:52 PM   #535
Avro Arrow's Avatar
Next, Ring of two:
Old 30th October 2012, 06:53 PM   #536
pls try to do a BF862 casoded Jfet CCS
Old 30th October 2012, 06:53 PM   #537
Avro Arrow's Avatar
And last, TL431 based:
Old 30th October 2012, 06:54 PM   #538
Avro Arrow's Avatar
Just some food for thought...
Old 30th October 2012, 07:06 PM   #539
the TL431 has high impedance but starts loosing it after only 1K, but is stiller better at 100KHz than the two other... Can you make one cascoded Jfet... ??
Old 30th October 2012, 07:24 PM   #540
Originally Posted by georgehifi View Post
Thanks Ken, so this is not an ideal circuit for a PCM1704 then? as to get 2v out, the loading for the dac would be too high at 2.35kohms? When the ideal should be much lower, around 10-100ohms. Is this correct? still learning about I/V's.
Cheers George
George, whether a 2.35k output impedance is too high or not will mostly depend on the total amount of shunt capacitance presented by the interconnect cable (typically, about 50pF per foot) plus that of the input of the next gain stage. The output impedance forms a low-pass filter in conjunction with that shunt capacitance.
Output impedance in itself does not say anything about the sound quality of a line level gain stage. For example, the Hovland HP-100, for example, was a very highly regarded tube linestage having a 2.4kohm output impedance.
Ken
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
