dac I/V convertion with very low distortion - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th August 2012, 08:36 PM   #31
dirkwright's Avatar
Originally Posted by smms73 View Post
this topology is not like Dr.Leach. I dont see how to use the current mirror
Are you sure that you understand how it works?
If you can't figure out how to use a current mirror in this circuit after reading the Leach article, then I wonder how much you really understand the circuit you made.
Old 7th August 2012, 09:26 PM   #32
Joachim Gerhard's Avatar
smms, that cap would short the bases of the input stage, so there is a low impedance path that lowers the noise. Only the emitter resistors and the base-emitters of the input transistors whould then be in the noise chain. Say we drive the input transistors on 5.5mA each and use BC327-BC337 we end up with 10 Ohm / 6 plus 30 Ohm / 6 = 6.666 Ohm.
That would be a very low noise input.
Old 7th August 2012, 09:26 PM   #33
I can try if that works in praxis.
Old 7th August 2012, 09:39 PM   #34
smms73 is offline smms73  Portugal
smms73's Avatar
Sorry, i did not pay too much attention to the article. i see what you mean, i will try that, thanks.
Old 7th August 2012, 10:36 PM   #35
smms73's Avatar
praxis is practice in german ?
Old 7th August 2012, 10:46 PM   #36
That was a typo sorry. I use a measurement program called "Praxis" so that intruded into my mind.
Old 7th August 2012, 10:51 PM   #37
By the way i find your circuit fascinating, i have not seen it exactly that way and i have seen many. I find it innovative whatever others say. I am just working to make it low noise into low impedances.
Donīt care about the thread jackers, that happens all the time when you enter an open forum.
Old 8th August 2012, 06:11 AM   #38
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Hi Zinsula,
i was told that the output impedance of the pcm1794 is 2M with 22pf, try to find in internet for the real value, but no luck .
[...]how do you come to 1k , i think is very low for a current source, if someone knows the real value please post.
Oh, I didn't realise, you are designing with a D/S DAC in mind.
I live in the stone age of R2R DAC's (PCM1704 / AD1862 et al). Their output impedance are in the range of 1 to 2kOhms. There is data posted at another forum.
Delta Sigma DAC like PCM1794 work differently and might have quite higher output impedance, but I have no idea how high it is. 2M seems a lot though.
Anyway, they seem to be less picky regarding the impedance they see at the output.
If you can't trust your ears, then CLICK HERE
Old 8th August 2012, 08:36 AM   #39
zinsula's Avatar
i'm going to try to explain how this topology works.
Its very simple, look at this image, we have a current source I2 , this current is divided by the input and output, if the input current increase 1ma the output must decrease 1ma, its similar to a differencial stage, there is no current gain, so this topology is more like a current mirror than a amplifier.
It's a folded cascode stage. Some even replace the ccs (I2 in this simplified schematic) with a resistor, as it forms a ccs anyway.
See here what I had in mind some years ago...you may also see how you can bias the input transistors.
It mirrors the input current to the high impedance node (collector).
I still do not really get what the transistors Q7 and 8 are doing special other than providing a low impedance biasing for the folded cascode transistors Q3 + 6 (kinda darlington folded cascode).
Can you enlighten me?
Old 8th August 2012, 12:24 PM   #40
Zinsula, i can not see your circuit because i am not a member of DIY.org
Can you post it here ?
The way i see the smms73 circuit is how he deals with the base currents. Q7 and Q8 pick up the base currents on the emitters and feed a portion in on the other side ( polarity ).
This is a kind of base current feedback.
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright Đ1999-2017 diyAudio
