dac I/V convertion with very low distortion - Page 34 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th August 2012, 11:29 AM   #331
smms73 is offline smms73  Portugal
smms73's Avatar
Default HI-ZEN
Another one ( HI-ZEN )
distortion 0.000022% at 8ma pp 10khz
V3 and V4 will be a complementar Vbe multiplier.
I like this one
Sérgio Santos
Old 24th August 2012, 11:34 AM   #332
smms73's Avatar
Originally Posted by Joachim Gerhard View Post
Circuit ideas are popping up here like flowers in spring ! I really have fun. This is very different then other threads where is only talk. I appreciate it.
Enjoy the spring while it lasts, because the gardener has to go back to other projects
Sérgio Santos
Old 24th August 2012, 11:42 AM   #333
smms73's Avatar
A paper that i find yesterday By Malcom Hawksford
http://www.essex.ac.uk/csee/research...%20cascode.pdf
Sérgio Santos
Old 24th August 2012, 05:22 PM   #334
smms73's Avatar
0.00005% 10khz 8ma-pp 500ohm input 0,5v rms out
this use BISS transistores from nxp, very good for low inpedance input.
Datasheet:
http://www.nxp.com/documents/data_sheet/PBSS302NZ.pdf
Sérgio Santos
Old 24th August 2012, 05:29 PM   #335
dirkwright's Avatar
Datasheet:
Whoa! cascoded darlingtons! cool! I like this one a lot!
I don't think you need C1 if you are operating in class A.
Old 24th August 2012, 05:32 PM   #336
Joachim Gerhard's Avatar
I worked with Malkolm in the 90th. I know his work well.
This BISS transistors are really special. Not much voltage they can stand but a lot of current !
I would still try one of your circuits an an input stage for a phono. I could not stabilize the first circuit i made. What do you recommend i could try ?
Old 24th August 2012, 05:35 PM   #337
dirkwright's Avatar
I came up with this a few weeks ago. Performance is not that good, but maybe it just needs some different transistors. I'm not experienced enough to know for sure.
Old 24th August 2012, 05:41 PM   #338
smms73's Avatar
One thing that i like in the ZEN style is the way the output capacitor (c6) serves to limit the band of the amplifier and to stabilize all the circuit.
It need a good power supply.
Sérgio Santos
Old 24th August 2012, 05:46 PM   #339
smms73's Avatar
I think you should try snubbers, there are some examples in some of the circuits i post. try the nodes that i call UP and DOWN, or at the input, but it help if you post a circuit.
Sérgio Santos
Old 24th August 2012, 05:48 PM   #340
OK, i will do that, what i have.
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 02:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 05:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 01:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 01:40 PM
Copyright ©1999-2017 diyAudio
