| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#281 |
the opamp in the opamp cen? circuit is working in floating supply ,but the noninverting input is tied to GND.
so it is almost equivalent to working in grounded supply ,and inputted IV converted signal voltage. therefore, the opamp is requied same property of ordinary IV opamp , high slewrate and short settling time. additionally, small base current at input stage.(base bias current and current through Cob) it may be fun to replace input stage of smms73's circuit with opamp. |
#282 |
Hence JFET input opamp, such as OPA1641 (post #272). > the opamp requires same property of ordinary IV opamp, high slew rate and short settling time. I think this affects more the IV input (opamp output) voltage variations than the current conveyed. As long as +Vin is not leaking current to Gnd, Kirchoff's law takes care of the rest at the output (R_iv). Patrick
xen-audio.com |
#283 | ||
OPA627 may be good why its input stage is bootstrapped. Quote:
the voltage will be V/I converted with the Zout of DAC and conveyed to output. this may affect especially pcm1704(Rout is 1kΩ) and so on. this is why I planned to include the base common amp in the feedback loop, at first. |
#284 |
This is special for Patrick. all JFET input.
with jfet we can simplify the circuit. But i dont have sk170/sj74 spice models. Can someone post them ? This may perform better that the cen circuit as there is no voltage variation at the JFET´s, and don´t need a battery. I dont have much experience with jfet and i have one question, if the gate voltage get's positive the gate current increase or in this type of jfet this is not a problem?
Sérgio Santos |
#285 |
Or this one all jfet
( the current sources can also be made of jfet if one wants to )
Sérgio Santos |
#286 |
another plan of output stage
#287 |
And this was the original circuit (or close )... very long time ago.
I was using tubes and no feedback at that time. This was the input and voltage amplifier of a hibrid power amplifier the output was a triple with Transistors, this was not constructed. Is a very good driver for a triode single end with that low gain valves like 2A3, 300b, 6c33c etc... edit: the triode was the ecc88 (6dj8)
Sérgio Santos Last edited by smms73; 22nd August 2012 at 09:38 AM. |
#288 |
Very clever Shinja, nice way to get rid of the CEN battery.
Sérgio Santos |
#289 |
But your circuit dont give a constant voltage for the input stage, my output topology do a better job in lowering distortion.
I think your idea was to get rid of the battery in CEN, was not it?
Sérgio Santos |
#290 |
I have been looking for 2sa1015/2sc1815, and toshiba goes to stop production, but there is a SMD version 2sa1162/2sc2712. it seem a good choice, thanks Joachim and Shinja.
Sérgio Santos |
| ultra low noise low distortion preamplifier needed | neazoi | Solid State | 13 | 11th October 2011 01:03 PM |
| IRF610 I/V convertion from Pass Labs D1 dac - single ended | schiller | Digital Line Level | 5 | 15th October 2009 04:33 PM |
| Distortion+low volume.. | GeirW | Tubes / Valves | 5 | 25th November 2004 12:04 PM |
| Best low-noise low-distortion buffer? | borges | Solid State | 7 | 9th December 2003 12:40 PM |
