dac I/V convertion with very low distortion - Page 21 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th August 2012, 10:31 AM   #201
smms73 is offline smms73  Portugal
smms73's Avatar
Originally Posted by Joachim Gerhard View Post
Something practical. LowDist I/V MC nearly ready.
Hope it don´t end up to be a oscillator, you have to slow it down, do not forget.
Old 16th August 2012, 11:54 AM   #202
Joachim Gerhard's Avatar
Yes, the circuit i build makes some trouble. I have one or two ideas to try though.
I will publish what i have at the moment. Maybe somebody has an idea how it can be made to work.
Old 17th August 2012, 12:05 PM   #203
smms73's Avatar
I have decided to follow Calvin suggestion of using a current source to cancel the dac offset current.
The current offset and dc out is now control by a R29 (that will be a 1k resistor in serie with 1k potentiometer ).
I have added C8/R25 C10/R26 C4/R24 for stability.
And now every thing seems to be very stable, the most sensible nodes are the nodes named UP and DOWN.
If you wish, the input zobel can be omited, but i keep them, because i feel it add stability.
The main current sources ware also changed (v5 and V4 will be two green led in serie).
Old 17th August 2012, 12:10 PM   #204
smms73's Avatar
What type of troubles ?
I will be glad to help if i can.
I start already to make the pcb for the circuit above.
Old 17th August 2012, 12:16 PM   #205
I bassically build your input stage but with a floating single supply like the Zen,Cen.
Ether the circuit does not work this way and needs a plus-minus supply or i have problems with stability. The scope shows some wild waveforms.
Old 17th August 2012, 12:31 PM   #206
smms73's Avatar
Below are the frequency response of the circuit before the modifications and after.
As you see the old version start to misbehave above 20Mhz With two enormous peaks at 33Mhz and 88Mhz .
The new version has a much stable frequency response
Note that this frequency response are measure without the output capacitor C1. The last figure is the response with the output capacitor.
Old 17th August 2012, 12:34 PM   #207
smms73's Avatar
if you post a schema maybe i can help.
Edit: I have to take a better look to the sen/cen circuit as it seems are a lot of people interested.
If i understand you . you change the jfets by the bjt´s.
Old 17th August 2012, 01:07 PM   #208
smms73's Avatar
Is this what you intend to do ?
Old 17th August 2012, 01:50 PM   #209
Yes, that is the circuit. I reduced R13, R14 to 2kOhm and put a ballast resistor after the electrolytics of 220 Ohm. The electrolytics are 470uF Nichicon bipolar.
Old 17th August 2012, 01:51 PM   #210
I see you have also a ballast resistor R6.
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
