Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 8th February 2013, 12:54 PM   #821
smms73 is offline smms73  Portugal
smms73's Avatar
Originally Posted by keantoken View Post
. R13/C2 looks potentially problematic and may make it prone to oscillation with inductive source impedance. This can usually be fixed with an input shorting cap, but point is to be aware of the issue so that you know what is going wrong and why in case of problems.
The bootstrapped cascodes creates a loop that is prone to oscillate at rf , R13/c2 is for adding loss at high frequencies, normally I have good results with this, in theory the c2 should be connected to positive rail, but in that way the PSRR at high frequency get worse.
I have see a lot of bootstapped cascode designs without any means to stop this oscillations to occur . But that is not much advised.
SÚrgio Santos
Old 8th February 2013, 01:05 PM   #822
smms73's Avatar
I ordered a bunch of ferrite beads a while back which have been sitting in a bin. These can be quite helpful. I wish I had tried them out sooner. They're easy to test on a prototype and instantly reusable. Like any reactive component, you have to know how to use them, but they can make you work less for the same result
Ferrite beads are non linear inductors ( hysteresis curve of ferrite ), some discourage the use of ferrite beads in audio circuits ,what is your experience with them , do they increase distortion?
SÚrgio Santos
Old 8th February 2013, 01:39 PM   #823
smms73's Avatar
Speaking of parasitic inductances and Just for curiosity , the most problematic situation that i enconter was with eGaN FETs , this type of FETs dont even have leads and have several souces and drain connections in parallel to lower to the extreme the parasitic inductance, at the speed they can switch the slightest inductance can cause ringing with enought voltage to damage them , especially in the gate that have maximum gate source voltage of 6 volts.
simulation with pcb traces parasitic inductances , in power switching is a must.
this is the link for the fets that i was talking (they are the future):
EPC2001
SÚrgio Santos
Old 8th February 2013, 01:54 PM   #824
smms73's Avatar
I End for now, with this citation that seems appropriate, and sadly very true.
"Every Amplifier is Waiting to Oscillate and Every Oscillator is Waiting to Amplify"
by Bonnie C. Baker
SÚrgio Santos
Old 8th February 2013, 03:02 PM   #825
smms73's Avatar
just for show how even a 0.5nH (a to220 lead has 12 nH of inductance) can have impact, i post this circuit the first without the drain parasitic inductance (500pH) the second with the added parasitic inductances, this is a extreme example and i just post it here for curiosity, in non swithing audio aplications this is not that bad .
with 2nH of parasitic the switch node reach 75 volts because of riging.
simulating this circuit without the pcb trace parasitic inductances can have drastic consequencies.
SÚrgio Santos
Old 8th February 2013, 11:52 PM   #826
keantoken is offline keantoken  United States
keantoken's Avatar
I'll use my current prototype as an example. I have an error correction buffer going to a simple IRF250 power buffer. The buffer is an advanced circuit of mine, the power buffer is just a source-follower biased at 500mA with a 10R resistor (driving 8" FR's). Without using ferrite beads, I might dicker around endlessly with the circuit, trying different compensations, RC snubbers, even regressing the design just to stop parasitic oscillations and reactivity that result in sibilance and fatigue. Maybe because I am using a 10R gate stopper for the IRF250, since I don't like the sound of a large gate stopper. But if I use ferrite beads, I can simply add one or two in series with the output of the line buffer, and this is pretty effective for eliminating sibilance in this application without losing the image depth and clarity that is so hard to achieve. Maybe not quite the same circuit, but it's worth a try.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 12th April 2013, 03:42 PM   #827
Telstar is offline Telstar  Italy
Hey Sergio, any news on your lovely circuit?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 10th October 2013, 09:35 PM   #828
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
Originally Posted by Shinja View Post
I know this is a bit late, but what is the benefit of this? All the noise from the psu will be injected in the signal, not?
So why is it so clever?
For some reason I cannot quote a pic, I'm referring to this post:
http://www.diyaudio.com/forums/digit...ml#post3133418
I'm that guy who finds ways *not* to do things..
Old 11th October 2013, 02:53 PM   #829
Nikitas's Avatar
The supply could be a battery now that I think about it....
But, still, how on earth does the opamp work?!
Old 11th October 2013, 08:30 PM   #830
smms73's Avatar
That is a circuit that uses floating power supplies , first I think you should check this thread to grasp the concept, then if you still need I will explain the rest. Dont forget that the current that is injected to the circuit by the I1 will have to return to ground and the only path is by the output resistor.
http://www.diyaudio.com/forums/digit...converter.html
SÚrgio Santos
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 02:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 05:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 01:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 01:40 PM
