Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 8th January 2013, 10:03 AM   #781
Calvin is offline Calvin  Germany
Calvin's Avatar
The Datasheet says 50Ohms.
There are Sim-Models for the AD844.
With these models the simmed value of Zin would be around 60Ohms, going down proportional to the number of paralleled devices.
THD sim-results depend to a great deal on DAC-Zout, increasing with decreasing DAC-Zout (H3 dominating, hence no cancellation in balanced mode).
Noise sims quite ok for the CC-part, but not as well after the Buffer.
Paralleling devices seems obvious, but may be too costly. 4 devices paralleled would probabely allow to even drive 32Ohms Headphones directly.
jauu
Calvin
Old 8th January 2013, 10:22 AM   #782
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by zenelectro View Post
QSP, FYI - and you -should- know this by now:
zero FB = no global or inter-stage FB. Usually means no local FB but in the
case of the Wadia CCT and this threads I-V there are small amounts of + FB.
Get used to it, that's the terminology that has evolved and we don't need
another 100 posts discussing the fact that an EF has 100% FB etc etc.
We -all- know what you are talking about, it's just an accepted terminology,
right or wrong.
yeah OK, it just bugs me thats all... when knowledgable, sometimes industry people perpetuate incorrect terms. When this happens, people who do not look past the terminology used, or the surface level ie not DIYers (technofiles), or beginner DIYers get the wrong idea of how a circuit works.
it validates in some manner the ******** marketing used by the industry and audiophile press. many times its used for circuits with MUCH more feedback than here and the term is used to elevate the 'purity' of the design, a design often packed full of feedback, perhaps more than a circuit that has a small amount of global feedback.
ive seen it used to describe Dacs.... Chock full of feedback.
accepted or not its incorrect, or perhaps less stringently... just incomplete.
but OK no more preaching to the converted, I know you understand it George and your comments are totally harmless, its mainly for those others with less intimate knowledge of electronics.
Old 8th January 2013, 10:51 AM   #783
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
jauu
Calvin
Thanks Calvin, I did see that it's 50ohm on the data sheet, but correct me if I'm wrong but that's when the feedback resistor R1 is in place, in the Pedja Rodic configuration this R1 feedback resistor is not present, so is it still 50ohms or does Pedjas TZ resistor to ground have a bearing on the input impedance as seen by my PCM1704?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 8th January 2013, 11:26 AM   #784
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by georgehifi View Post
Funny you should bring up the AD844 Jan.
I found this circuit of Pedja Rodic's (attached) and used it as is (NO FEEDBACK) and it worked a treat, best opamp based I/V so far by a long way, it blew the OPA627 completely away I though it would never be beaten except for a discrete I/V of some sort. (And I’ve tried just about every opamp out there)
I used it without feedback as per the diagram and was very very happy. Used with TZ as he has it 1.5K with 1000pf to ground, I think this gives a 1st order rolloff –3db @100khz.
Does the 1.5k resistor have a bearing on what input resistance the dac (PCM1704 in my case) sees?
Because I changed the resistor for 2.2k to get some more gain but this time with a 260pf cap –3db @ 270khz (still all nice and stable with a bit more gain) still very very good.
But I had the feeling it was puchier and more dynamic with the 1.5k resistor even though I had less gain. I feel that the input loading for the PCM1704 is better with the 1.5k than the 2.2k resistor or am I imagining things?.
Cheers and thanks for your input George
No the Tz resistor has no impact on what the DAC sees.
BTW If you really want to leave the DAC alone, why not do the DC servoing at the Tz node?
Or, as I do in one implementation, do the DC servo to pin 3, that's hi-impedance point.
Also C1 seems superfluous, being in parallel to what is it, 15 ohms?
Also, you could try following the Tz output with an external opamp as buffer and/or amplifier, as the internal buffer is probably not that good.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 8th January 2013, 12:10 PM   #785
regal is offline regal  United States
The NTD1 has feedback, I don't think anything short of the magical wire with gain as no feedback as you are asking for. Hell any active device has feedback. Matter of fact if you design a circuit without feedback you should apply for the Nobel prize cause you can break the second law of thermodynamics and have created a perpetual motion machine
When we speak of NFB free I/V conversion all we are doing is talking about minimizing the impact of the speed of light/electrons on the conversion process (keeping the feedback small,fast, and local) so the conversion is better.
Old 8th January 2013, 08:12 PM   #786
smms73 is offline smms73  Portugal
smms73's Avatar
BTW Sergio how is yours going? have not heard anything for a while?
sorry for the long absence guys, but December is always a complicated month , and is also a time to give family more attention.
Hope you all had a good holydays.
SÚrgio Santos
Old 8th January 2013, 09:03 PM   #787
smms73's Avatar
Originally Posted by jan.didden View Post
I've used the AD844 in CCII role (open loop) in power amp feedback/error correction circuits with excellent results.
jan
I think you are talking about the PAX amplifier.
In the last 3 weeks i have been studing with more attention the Hawksford error correction, and have come up with my one solution to sense the output error, I have already test it with the simulator and work better that i was expecting, as the error correction circuit that i use don┤t degrade the phase of the output stage, it is very tempting to use a feedback loop around it and get immeasurable harmonic distortion.
But the thing that realy gets my attention in the Hawksford error correction is the
capability to make the amplifier more insensitive to variations in impedance of the loudspeakers.
about your amplifier, I wonder why you did not put a trimmer in serie with r25 (4k99) , to minimize the distortion.
Didden , your amp and the ingenious ideas of Dr. Hawksford was a source of inspiration and made me change my course regarding my next amplifier project. Thanks for sharing your knowledge.
SÚrgio Santos
Old 8th January 2013, 09:36 PM   #788
qusp's Avatar
what? Regal what the hell are you going on about? do you read the posts you reply to? I just finished saying (more like ranting) that its impossible to have no feedback solid state circuits since the devices cannot exist without it and I get you arguing with it as if i'm asking for no feedback? what exactly in my post are you arguing with?
if it wasnt bad enough they had to put up with my anal pickiness, they get you imagining I have a viewpoint to argue the point against AGAIN. and your argument 'coincidentally' is exactly what I just said...
Old 12th January 2013, 01:06 AM   #789
georgehifi's Avatar
Re Pedja Rogic's I/V AD844 (with no global feedback) it is a game changer and it's hard to believe that a discrete I/V can get better than this, but I hope it does.
But this thread is not the one where it should be disscussed, please go here.
http://www.diyaudio.com/forums/digit...ng-opamps.html
Cheers George
Old 2nd February 2013, 08:19 PM   #790
keantoken is offline keantoken  United States
keantoken's Avatar
It looks like most of your distortion comes from the input stage. It runs open-loop without any compensation so distortion derives directly from the logarithmic transfer function of the inputs. Theoretically you could minimize distortion by degenerating the input stage at 26mV, or around that point where there is the 3rd harmonic null.
Also, your cross-connected Baxandall type VAS is good but I compared it to the traditional complimentary Common-base Baxandall VAS and it has inferior PSRR. Have you tried Edmond's arrangement in figure 5 here?
Super TIS
There is little need to bias Q5 and Q7 higher than a few hundred uA, just enough to swamp the Ib of Q10 and Q11. R12 improves PSRR by another several db's but this isn't necessarily possible in your circuit.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
