Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 7th January 2013, 07:40 AM   #771
qusp is offline qusp  Australia
qusp's Avatar
In contrast, the SwiftCurrent circuit performs this I/V conversion with Wadia’s patented current-conveyor integrated circuit (IC) that eliminates feedback. This bipolar IC consists of an innovative connection of Wilson current mirrors, an emitter degeneration compensation scheme to optimize transient response and stability, and a novel current mirror arrangement to enhance output impedance."
hmm as usual the claims of no feedback are smoke and...mirrors. conveniently deeming degeneration not part of the feedback network.
it still sounds very interesting Jan, so keen to see your schematics.
Old 7th January 2013, 05:49 PM   #772
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Well I don't know, how can you learn anything with your mind already firmly made up
But here goes.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 7th January 2013, 06:26 PM   #773
qusp's Avatar
degeneration is feedback, thats all i'm saying, 'no feedback' is a marketing term. that doesnt mean it cant be an interesting circuit all the same
the thing is full of local feedback/degeneration, its pretty darn cool though
it has no global negative feedback, I just wish that was the term people used, but they almost never do.
thanks for the scheme BTW, another one filed for later.
Old 8th January 2013, 12:21 AM   #774
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
But here goes.
jan
WRT Wadia I-V, It's a pretty complex circuit that doesn't really bring a huge
amount of linearity to the table. It won't come close to the circuit in this
thread.
With careful design, a lot simpler [open loop I-V's can do aswell or better
than the Wadia.
It's also arguable that it is a true open loop design as there is + feedback
used to iron out IP BJT non linear emitter resistance.
Old 8th January 2013, 02:48 AM   #775
Shinja is offline Shinja  Japan
I found an article from wireless world here.
Index of /Wireless-World-Stuff
PA630 looks not so complex circuit, but just a CC1 with buffer.
Old 8th January 2013, 07:17 AM   #776
jan.didden's Avatar
BTW I have had very good results with the AD844, another CCII with buffer. In contrast to the PA630 it is a balanced circuit instead of single ended, although that only manifests itself in somewhat better DC characteristics.
I've used the AD844 in CCII role (open loop) in power amp feedback/error correction circuits with excellent results.
jan
Old 8th January 2013, 07:31 AM   #777
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Funny you should bring up the AD844 Jan.
I found this circuit of Pedja Rodic's (attached) and used it as is (NO FEEDBACK) and it worked a treat, best opamp based I/V so far by a long way, it blew the OPA627 completely away I though it would never be beaten except for a discrete I/V of some sort. (And I’ve tried just about every opamp out there)
I used it without feedback as per the diagram and was very very happy. Used with TZ as he has it 1.5K with 1000pf to ground, I think this gives a 1st order rolloff –3db @100khz.
Does the 1.5k resistor have a bearing on what input resistance the dac (PCM1704 in my case) sees?
Because I changed the resistor for 2.2k to get some more gain but this time with a 260pf cap –3db @ 270khz (still all nice and stable with a bit more gain) still very very good.
But I had the feeling it was puchier and more dynamic with the 1.5k resistor even though I had less gain. I feel that the input loading for the PCM1704 is better with the 1.5k than the 2.2k resistor or am I imagining things?.
Cheers and thanks for your input George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 8th January 2013, 08:52 AM   #778
qusp's Avatar
again, how is that No Feedback? conveniently thinking of local and internal mechanisms as something other than feedback does not make it so. transistors inherently have feedback, it cannot be switched off no matter how you arrange them.
Old 8th January 2013, 09:43 AM   #779
zenelectro's Avatar
QSP, FYI - and you -should- know this by now:
zero FB = no global or inter-stage FB. Usually means no local FB but in the
case of the Wadia CCT and this threads I-V there are small amounts of + FB.
Get used to it, that's the terminology that has evolved and we don't need
another 100 posts discussing the fact that an EF has 100% FB etc etc.
We -all- know what you are talking about, it's just an accepted terminology,
right or wrong.
Old 8th January 2013, 09:49 AM   #780
georgehifi's Avatar
OK, no global feedback.
Whatever it's got it's got magic like there's no rev limiter, and I have no idea what the distortion is but it sounds distortionless, it presents my cd's in a totaly different way than I've ever heard them.
I would love to know what the input impedance is configured this way, but I suppose only Mr Gilbert the designer for ADI would know has he only knows the whole circuit.
All other opamps for I/V sound a little different tonally to each other, but this AD844 "with no global feeback" has made my whole cd collection a new listening experience.
Cheers George
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
