Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 15th December 2012, 01:58 AM   #751
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by EssB View Post
Hey Dirk,
I think Sergio is working up to TO-3, he's going for TO-126 (BD139/140) first ;-)
Good work Sergio!
It's only a matter of time my friend, only time. Eventually, everyone goes for a TO-3. It's the biggest hammer in the tool box.
Old 15th December 2012, 02:13 AM   #752
smms73 is offline smms73  Portugal
smms73's Avatar
Originally Posted by Shinja View Post
hi smms
I considered CFP but dismissed.
the CFP itself is 2 stage feedback amplifier, then it has slew rate limit, moreover asymmetrical rise and fall.
I think the charactaristics are not suitable for our application.
I will investigate that. In simulation it gives good results even with 50 ohms input impedance.
One thing is for sure . the bias of the input transistors have to be between 60ma and 100, for increase linearity, we have to use some to126 devices with heatsink or paralleling some pairs of BC327/337.
Using feedback with this type of dac are very tenting
SÚrgio Santos
Old 15th December 2012, 04:23 AM   #753
regal is offline regal  United States
Originally Posted by smms73 View Post
To increase flexibility and compatibility with more dac chips, I have included a reference voltage input , for use with dacs that need a offset voltage at the input, like ess9018 , ess9012. The new input is the one named "SET".
Have you tried this I/V with the TDA1541, I imagine the SET is where one would inject the 2mA offset it requires?
Old 15th December 2012, 04:02 PM   #754
staccatiss is offline staccatiss  Germany
No problem with 60-100mA! Plenty of good devices to use. Size TO220 is also possible. For ex the audio drivers
2SC4973+complementary
2SC5171+complementary (very linear, fast)
/S
Old 15th December 2012, 05:08 PM   #755
jcx is offline jcx  United States
modern CFA op amp do much better than descrete Q at their appropriate power, V levels
pwr pad CFA op amp like TPA6120 do single digit W, >200 mA, and have ppm audio distortion specs - and work up to 100 MHz - in closed loop
why would anyone today lust after big Q in DAC I/V?
Old 16th December 2012, 10:19 PM   #756
smms73's Avatar
jcx. This circuit is not a cfa. It has no feedback loop, but it uses some techniques to make it very linear.
SÚrgio Santos
Old 16th December 2012, 10:33 PM   #757
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
I was not happy with the solution of paralleling 4 board for the es9012 / 9018. I have thought in using a different input for this type of dac , it has less than 500mohms of input impedance, it is biasing at 60ma . what you guys think ?
Q1 and Q2 will be bd139/bd140.
meanwhile i am waiting for the components to arrive to try my test boards.
Now you are getting a little lazy, using CFP connected transistors to handle
the high current swing / low OP Z of Sabre.
You can get -super- low distortion fron Sabre using very simple open loop
I-V , even without the small + feedback loops, but you must think very
laterally
ZZ
Old 16th December 2012, 10:37 PM   #758
zenelectro's Avatar
hi smms
WRT CFP, I agree.
In fact I consider the small + feedback loops a violation of the open loop theme
- but that point could be argued forever, life is too short
Old 16th December 2012, 10:46 PM   #759
dirkwright's Avatar
Yes, oh yes, soon will come the day when you give up on those wimpy little transistors and embrace your true manhood with a pair of TO-3 monsters.
Old 16th December 2012, 10:54 PM   #760
zenelectro's Avatar
And the bigger the bjt the slower / more non linear it is.
There is an art to picking the right device for a particular place in this
circuit and running it at the right current.
Z
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 02:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 05:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 01:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 01:40 PM
