Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 13th November 2012, 10:00 PM   #621
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
I asume MiiB that for the PCM1704 you are saying this (attached red circled) has to be change to 2kohm and 870pf as Serg says?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 13th November 2012, 10:07 PM   #622
georgehifi's Avatar
Sorry, just done the calculations, and yes both values of cap and resistance are -3db at 90-95khz.
Thanks George
Old 13th November 2012, 11:17 PM   #623
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
Originally Posted by smms73 View Post
I didn´t know that you leave sonics i have to check Canalis.
The difference in this implementation is that normaly you see DC servos connected to input of the amplifiers and the noise of the servo opamp will be injected in the main amplifier, so you need to use a audio grade opamp for low noise like opa627 , but in this case the servo is not in the audio path (as Ken Newton has explain in post#561) so you just need to use a opamp with low input offset , the noise is not important (like for exemple max4238 less than 1€ and much beter in dc precision than audio opamps).
This is more economical (opa627 cost more than 20€) and better sonically as the servo is not in the audio path.
It doesn't matter where you connect the servo, it is -always- in the audio
path. Over the years this discussion has come up repeatedly.
The servo has to adjust the -audio- OP DC level and do so by integrating
the audio itself. Every servo works this way, you can connect them wherever
you like but if they are to work, they are in the audio path.
As such they definitely are audible and can often sound worse than a good
coupling cap. I know people who have in fact gone to extreme lengths to
make the servo truly out of the circuit, one worked on heat feedback and
another was a sampling system which made small adjustments at pre defined
time intervals, otherwise being off.
Just socket the opamp and try swapping it - you might get a surpise
Thanks George
George,
The optimum value of the LPF cap will probably be system / DAC dependent.
You might even get away without one, if the I-V is stable as such. The
1704 has low OOB noise.
WRT the 2k OP resistor, I would first try this I-V without an OP buffer.
It may well sound better 'in the raw' so to speak.
The issue with OP buffers is you will be hard pressed to find a design that
preserves the linearity of this I-V's super low distortion.
It will almost certainly require some sort of bootstrapping.
Old 13th November 2012, 11:27 PM   #624
georgehifi's Avatar
Originally Posted by zenelectro View Post
George,
Hi Zen, I need the lower output impedance of the buffer, (BTW what is the output impedance with and without buffer)? as this needs to push into the Lightspeed (10k'ish) together with whatever the poweramp may be, total can come down to 7k'ish. I also love the idea of direct coupling, hopefully with dc servo. When all is finalized
Cheers George
Old 14th November 2012, 06:43 AM   #625
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Originally Posted by MiiB View Post
[...]As the PCM1704 and also the TDA1541 operates +/- No counter-current is needed at the input.
Careful here. TDA1541 has 2mA offset and no ± operation.
Page 6 here.
If you can't trust your ears, then CLICK HERE
Old 14th November 2012, 07:03 AM   #626
smms73 is offline smms73  Portugal
smms73's Avatar
Zen, at the beginning I was reluctant in using a servo, because I am very aware of the problems that conventional servo has . Then I fought of adding a second pole to filter the AUDIBLE noises and distortions produced by the servo integrator , and this work very well, I have lost a lot of time trying to come up with a good solution for this , and I think that I have found it. But if someone with your experience thinks that this particular servo may have an impact in sound , others with less knowledge in analog design may as well feel uncomfortable , so I will add a optional trimmer in the PCB for manual regulation of DC offset.
I have made a lot of tests with this servo, and I can assure you that it has a minimum impact in audio band.
Please take a better look at this.
Sérgio Santos
Old 14th November 2012, 07:27 AM   #627
smms73's Avatar
Thank for the correction zinsula ,tda1541a is one that I will try for sure , as it served me well for over 15 years.
Sérgio Santos
Old 14th November 2012, 07:53 AM   #628
smms73's Avatar
Cheers George
You dont need a buffer just use a 2k5 resistor at the output, this resistor in parallel with the 10k of your atenuator will have the efective 2k out impedance that is require for 2 volts rms out.
Sérgio Santos
Old 14th November 2012, 08:25 AM   #629
MiiB is offline MiiB  Denmark
When you use the Light speed attenuator you sometimes see quite low impedance's hence my suggestion for a Buffer... If I was to make a product.. I would for sure include a buffer... I have often used the simple N-JFeT buffer, with no sonic penalty.
Regarding the servo I totally agree with Sergio.. this way of implementing the Servo has no sonic penalty. This type of servo simply adjust the driving currents on a DC level, and not like most servos by inserting a DC offset in the signal path.
Thanks for the correction on the 1541...This has slipped my mind. sorry.
Old 14th November 2012, 08:49 AM   #630
smms73's Avatar
MiiB there is no problem with low impedance at the output of tagus , you can even shunt the output to ground , there will be no damage, there is a good idea to use a attenuator at the output of tagus and then if you want , use a buffer.
Later i will post some ideas for buffers, and the method to include them in the DC servo loop.
I am looking for dual potentiometer with 1k or less for audio use, if someone know any, please let me know.
Sérgio Santos
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
