Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 29th October 2012, 02:55 PM   #511
smms73 is offline smms73  Portugal
smms73's Avatar
Just because much of you guys are curious to see the schematic of the I/V converter, this is what i have right now. Possible i will change some values but the final circuit will be very close to this.
second image is distortion with input impedance of 1Kohm 8ma p-p, third is 3Kohms 8ma p-p.
As you can see distortion is very low even at low input impedances.
Sérgio Santos
Old 29th October 2012, 03:03 PM   #512
smms73's Avatar
Forget to post this one that is with 3 volts rms output, 3 kohms input impedance. no visible distortion, distortion just start to became visible at 4.5 V rms.
Sérgio Santos
Old 29th October 2012, 03:05 PM   #513
smms73's Avatar
Today i have not much time to show you another test that i made with different´s output connection, but tomorrow i will post that.
Sérgio Santos
Old 29th October 2012, 05:22 PM   #514
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Sergio, very cool. Thanks, for posting the schematic. I'll offer further comment after I've had opportunity to model the circuit in my simulator. Specifically, I'm curious to examime how sensitive the circuit is to producing D.C. output offset, due to small amounts of parameter mismatch between the two complementary current sources.
Old 29th October 2012, 05:48 PM   #515
regal is offline regal  United States
This is amazing. Can you show a photo of you setup? Did you have to go through hundreds of transistors find a low dc offset?
Very elagant looking circuit, really hope it pans out.
Old 29th October 2012, 08:13 PM   #516
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Originally Posted by Ken Newton View Post
Sergio, very cool. Thanks, for posting the schematic. I'm curious to examime how sensitive the circuit is to producing D.C. output offset, due to small amounts of parameter mismatch between the two complementary current sources.
Yes this would be interesting, hate to see coupling caps used with this, then a dc servo wouldn't be too bad if needed.
Also Serg you showed 1k at 8mA PtoP source, how does it behave with something less like a PCM1704 which is 1Kohm but only 1.2mA PtoP? even better hopefully? Also what is the output impedance of this setup?
PS sorry so many questions how does it also behave over 100khz and above, input impedance wise and output distortions?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 29th October 2012, 08:46 PM   #517
Ken Newton's Avatar
Cheers George
George, the output impedance is essentially set by the value of the I/V resistor utilized. The I/V resistor value itself is determined by the fullscale DAC output current available for developing a 2VRMS signal level via Ohm's law. So, for the schematic shown by Sergio, the output impedance is 375 ohms.
For the PCM1704, I believe the fullscale output current is 1.2mA peak. The I/V resistor value needed to develop 2VRMS would be: 2.8Vpk / 1.2mApk = 2.35kohms. Therefore, the output impedance essentially would also be 2.35kohms.
Old 29th October 2012, 09:33 PM   #518
MiiB is offline MiiB  Denmark
SMMS... do you balance the circuit by unbalancing the current sources, or do you inject a counter current at the input... or do you use a transformer to get rid of the current offset...??
Old 29th October 2012, 11:10 PM   #519
georgehifi's Avatar
Thanks Ken, so this is not an ideal circuit for a PCM1704 then? as to get 2v out, the loading for the dac would be too high at 2.35kohms? When the ideal should be much lower, around 10-100ohms. Is this correct? still learning about I/V's.
Cheers George
Old 29th October 2012, 11:36 PM   #520
So let's say we have minimal DC offset. It may be a good idea to put some filtering after this and then a buffer. I'm thinking the DCB1.
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
