Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 17th August 2012, 11:15 PM   #231
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by smms73 View Post
Dirkwright it works but not with the very low distortion that my circuit is capable. Joachim wants to achieve my distortion levels with the simplicity of the
cen topology
Well, it's just a matter of a tweek here and a tweek over there. I just wanted to show that it wasn't an oscillator. I'm just trying to help out.
Old 17th August 2012, 11:15 PM   #232
smms73 is offline smms73  Portugal
smms73's Avatar
Originally Posted by Joachim Gerhard View Post
At the cost of some complexity it could be a voltgae in - current out mirror but then we come closer to component count of the original design.
Yes. And start to make no sense.
Old 17th August 2012, 11:18 PM   #233
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I would be happy with -100dB, but anyway. It all feels so familiar to me. Malkolm told me in the old days that I/U converters and MC inputs can have a lot in common.
I have virtually no experience with I/U converters for digital though.
Old 17th August 2012, 11:20 PM   #234
smms73's Avatar
It seems a stable circuit . Its strange to give problems to Joachim.
Old 17th August 2012, 11:24 PM   #235
smms73's Avatar
How much current a MC produce ? What is the gain you need?
Old 17th August 2012, 11:33 PM   #236
Optimal is a gain of 20x to 30x ( 26dB ), the cartridge i have has a DC impedance of 6 Ohm and puts out 0.5mV nominal. Because some records are cut hot ( plus 20dB ) and there is dirt and cracks on the record it can put out more then 10mV pulses, especially at higher frequencies.
Old 17th August 2012, 11:52 PM   #237
smms73's Avatar
that is very low. you shold be fine with the simple circuit that you construct. its stranje to have problems. if possible post the shema that you use. just to better visualization.
Old 18th August 2012, 12:03 AM   #238
Sure, it should work, I will make some experiments over the weekend and post the schematic.
Old 18th August 2012, 06:30 AM   #239
smms73's Avatar
One possible solution to make it low distortion is use a cacode with mosfet or jfet for the bias bjt, like the picture below. (this is only a test not a functional circuit)
Old 18th August 2012, 06:42 AM   #240
smms73's Avatar
another idea
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
