dac I/V convertion with very low distortion dac I/V convertion with very low distortion - Page 17 - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th August 2012, 09:05 AM   #161
smms73 is offline smms73  Portugal
smms73's Avatar
Originally Posted by Ken Newton View Post
Okay, today I took the time to enter the circuit in my simulator. I must say, I'm impressed. I randomly substituted all manner of various transistors throughout the circuit, and found the THD indeed remains in the vicinty of -140dB, although the specific profile of hamonics vary. This is highly unusal behavior for an open-loop bipolar circuit in my experience. Well done.
thanks Ken. what is the simulator that you use?
Old 14th August 2012, 10:34 AM   #162
smms73's Avatar
Originally Posted by Calvin View Post
THD seems really low, but input impedance rises above 1MHz with some weird up-and downs, especially around 66MHz, where seemingly a resonance builds up.
I have been analysing this, and the conclusions is
the rising of the impedance is due to the lost of gain of the input transistors as the frequency goes up.
The dips and ups around 66Mhz are due to the interaction of the dac output capacitance (22pf) with the input.
The best soluction is to use a snubber (zobel) in the input.
In the pictures below is the output and input gain and phase with the snubber and without it.
Its very important to use the snubber in the circuit.
Old 14th August 2012, 12:18 PM   #163
dirkwright is offline dirkwright  United States
dirkwright's Avatar
The dynamic signal current swing from EACH output pin is 3.9mA peak single-ended. Therfore, the peak-peak signal current swing from EACH output pin is 7.8mA single-ended. The DIFFERENTIAL output signal net current change for a given channel then is 7.8mA peak, and 15.6mA peak-peak.
I'm sorry this does not make sense, particularly in light of the chart in post #155.
Old 14th August 2012, 12:47 PM   #164
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Let's walk this through. The table in that chart you refer to shows two anti-phase output signals, IoutN and IoutP. You can read the peak-peak current magnitude for either output phase directly from the table, which is 10.1mA minus 2.3mA = 7.8mA. The signal current swing is centered around a BPZ (Bipolar Zero) bias current of 6.2mA. So, 10.1mA minus 6.2mA = 3.9mA peak, from BPZ, and then 6.2mA minus 2.3mA = 3.9mA for the opposite peak, from BPZ - from either output pin. The resulting 7.8mA pk-pk signal current swing is abailable from BOTH IoutP and IoutN. Now, since the two output signal currents move in anti-phase (they are differential), the differential peak-peak net signal current change is 2 x 7.8mA = 15.6mA.
Ken
Old 14th August 2012, 01:12 PM   #165
smms73's Avatar
Default TAGUS
Is time to present to you guys, the almost finished differential version that i resolve to call TAGUS.
It has a new current mirror that is also a voltage mirror.
The distortion is measure with a 500ohm/22pf input
and is 0.000130% at 7.8ma p-p at each input.
and only 0.000055% at 3.9ma p-p.
Below are the schema and the fft for 7.8ma and 3.9ma
I will talk about it later because today going to be a busy day, hope you enjoy.
Old 14th August 2012, 01:23 PM   #166
smms73's Avatar
Here are the I/V of the texas datasheet and the FFT just for comparing.
Old 14th August 2012, 01:43 PM   #167
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Cool, i like that mirror.
Old 14th August 2012, 01:49 PM   #168
smms73's Avatar
I am thinking in building this:
Modular audio DAC
and change only the I/V convertor, i like the modular idea.
What you guys think, if you have or know were to find a better pcb for a dir9001 and pcm1794a please let me know. I really dont have the time to design my one, thanks in advance.
Old 14th August 2012, 01:51 PM   #169
smms73's Avatar
have you ever seen one like this?
Old 14th August 2012, 02:08 PM   #170
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
Modular audio DAC
Are you aware that DIR 9001 only does 96k ?
The CS 8416 module does 192k.
I'm thinking you want to do the PCM1794A justice, so 192k!?
...and be prepared for a huge hunt for the TORX thingies....very scarce .
CV
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
