Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 10th August 2012, 05:34 PM   #101
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Looking again at post 99 the mirror around Q9, 10, 11, 12 is kind of redundant. The mirror that does the bal-unbal conversion is already a current source. Can be improved though.
Remove the base-collector short from Q17 and put in on Q23. Put in a helper transistor instead of short between base-collector of Q19, other side the same. That mirror has higher impedance and lower distortion.
Old 10th August 2012, 05:35 PM   #102
Shinja is offline Shinja  Japan
Hi smms73
thank you for testing my propose.
it is disappointing the circuit have poor performance.
how is the post #99?
does it mean to put emitter follower to supply base current of Q17 and Q23?
Old 10th August 2012, 05:49 PM   #103
smms73 is offline smms73  Portugal
smms73's Avatar
The ccs (q9,10,11,12) is necessary to feed the output. i have test all the possibilities you present, this is the best.
Old 10th August 2012, 05:50 PM   #104
Of cause then you have to raise the current in the right side of the input mirror to supply the output stage. This is interesting.
Old 10th August 2012, 06:12 PM   #105
smms73's Avatar
thanks for the explanation about noise. I was thinking that such a low difference in impedance were not so bad, anyway the circuit in post 99 is only a test circuit.
Unfortunately the current mirror degrades the distortion, this circuit has 0.0012% , its a great diference.
Old 10th August 2012, 06:29 PM   #106
Making of low distortion mirrors is possible.
Anyway, i am sure that you will find a satisfying solution.
Old 10th August 2012, 08:57 PM   #107
smms73's Avatar
Circuit with bc327/337 , as predicted it's even better at low input impedances, and has only 0.00001% of distortion with a 1k source at 2ma, at 7.8ma and 10k input it has 0.000021%.
It should be also good for R/2R dac. I am very pleased with this results, and the final I/V converter will be very similar to this.
Thank you all for your support, and a special thanks for Joachim, for your help in dealing with the noise issue.
I will start a prototype to test this in real life.
Old 10th August 2012, 09:59 PM   #108
smms73's Avatar
forgot to say that the input impedance is 2ohm can be further reduced with parallelling more bjt at the input or lowering the emitter resistances, but 2 ohm seems a low enough impedance for a current output dac.
The distortion is 0.000014% when simulated with the 6.2ma of offset at the input and 0.000017% (increase 2db in 2 harmonic ) without the offset so there is no problem in dealing with the offset of pcm1794, as i say before just increase 6.2ma in the upper current source, this results were simulated with 8ma/100k input.
Old 10th August 2012, 10:40 PM   #109
smms73's Avatar
sorry my mistake
The distortion is 0.000014% when simulated with the 6.2ma of offset at the input and 0.000008% (increase in 2 harmonic ) without the offset
Old 10th August 2012, 11:09 PM   #110
This is a fantastic result. I am looking forward to your build.
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 02:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 05:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 01:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 01:40 PM
Copyright ©1999-2017 diyAudio
