Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th December 2003, 01:55 PM   #11
cm is offline cm  Singapore
After struggling with both Philips CD players as mentioned in the firts post, ( one is a CD player and the other is a mini sound system ) and replacing both the CDM12.1 with new VAM 1202s, both the crappy stuff still says no disc.
Swapping back the older CDM 12.1 into the CD player and tweaking the variable resistor, the CD players comes back to life again, but only for a few days.
I am rapidly coming the conclusion as Jean Paul - scrap these crappy stuff. If new lasers cannot work on two different systems, there must be other common problems. I noticed that the head moves up and down a couple of time but is still unable to detect. I will try replacing the TDA 1300 lazer diode amp and it it still does not work.........philips
Both systems uses the same circuits, TDA1300, SAA 7372s and 3 TDA7073.
Any suggestions from anyone that is constructive before I go into a destructive mode?
Old 7th December 2003, 05:56 PM   #12
diyAudio Moderator Emeritus
jean-paul's Avatar
for clean the lens of Pick-up,using the "alcohol"is right, but the "alcohol" not same the normal alcohol (ethanol,C2H5-OH), true name is "lsopropylalcohol",the chemic name are "C3H3O",our factory using this solvent for lens clean in every day,for plastic CD/DVD lens no problme is ok too.
Isopropylalcohol is safe ( it is the main component in lens cleaner for cameras ) but in general people misunderstand when just the term "alcohol" is used. The chance that they will use (m)ethanol is high hence my advise to use distilled water.
It's only audio
Old 8th December 2003, 08:09 AM   #13
X.G. is offline X.G.  China
X.G.'s Avatar
Yes,Isopropylalcohol is hard to find.
I add a advice:cleaning the inner glass(below the lens) is more importan,but much be careful.
good luck.
Philips CDM3 laser pickup for which CD-player ? nnkp Digital Source 8 22nd December 2010 07:21 PM
Laser pickup adjustment on Accuphase CD player Lulu_the_cat Digital Source 1 24th January 2010 01:54 PM
What makes the best wide world amplifier..how to detect the one! destroyer X Solid State 39 16th April 2009 09:40 PM
'Signal detect' LED for a small audio amp? HankMcSpank Solid State 1 28th March 2009 06:33 PM
CD Player doesn't detect disc sometimes Gartak Digital Source 4 3rd January 2004 11:58 AM
Page generated in 0.06824 seconds (74.65% PHP - 25.35% MySQL) with 10 queries
