Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Using the new 2012 Shigaclone to create a killer high end transport
Old 13th February 2013, 12:25 PM   #81
tonyptony is offline tonyptony  United States
Tibi, not sure if I can track down an ESR meter. With regard to your method, however, shouldn't the use of the resistors not be needed if I have a constant current power supply? That's really all the resistors are doing in this case - insuring a small current to the caps during the forming process.
Old 13th February 2013, 12:49 PM   #82
tvicol is offline tvicol  Romania
tvicol's Avatar
Using the new 2012 Shigaclone to create a killer high end transport Using the new 2012 Shigaclone to create a killer high end transport
In fact resistor will act like a variable ccs. While the voltage is dropping the current will drop as well protecting the cap from overheating.
Tibi
Vicol Audio
Old 13th February 2013, 09:43 PM   #83
APK is offline APK  United Kingdom
Tibi
Can you please clarify how to split and where to power the various sections, motor 8.3v, digital 5v, and TentLabs oscillator If using "bobken" regulator for the digital section and a "pinkfish flea for the TentLabs oscillator?
Old 14th February 2013, 09:43 AM   #84
tvicol's Avatar
APK,
Document was updated to include these descriptions, version 1.6 - see page 8
https://docs.google.com/document/d/1...j9X4b7Q0/edit#
Tibi
Vicol Audio
Old 14th February 2013, 10:01 AM   #85
tvicol's Avatar
Do you think that Shiga will have any chance in front of a $ 18000 player ?
Tibi
Vicol Audio
Old 14th February 2013, 10:18 AM   #86
tvicol's Avatar
Well, we already done that.
Tibi
Vicol Audio
Old 19th February 2013, 01:06 PM   #87
Tibi
I have the power supply and will be doing the cap forming maybe tonight or tomorrow. The HP supply is a variable DC supply that can be set for constant voltage / constant current, but I'm not sure that's what I want to do.
I was thinking of setting up a cap with the 100KOhm resistor in series and then ramping up the voltage slowly until I get to 50 VDC. Or should I just set the voltage to 50 VDC, turn off the supply, hook everything up, and turn it back on?
Old 19th February 2013, 01:15 PM   #88
tvicol's Avatar
Set the voltage to 50V and let the cap to draw needed current trough 100K resistor.
Tibi
Vicol Audio
Old 21st February 2013, 10:03 AM   #89
dimkasta is online now dimkasta  Greece
dimkasta's Avatar
APK,
Tibi
Ι ve been trying to see how to upgrade the psu parts.
Where would you reckon would be the best place to ground the separate Vs?
Which V powers the motor driver?
Thanks again
Old 21st February 2013, 10:59 AM   #90
tvicol's Avatar
Thanks again
Dimkasta,
For separate Vs best place to ground is main board ground input - connector J5 Dout GND.
Motor driver need 8V. J6 connector is 8V.
Tibi
Vicol Audio
Using the new 2012 Shigaclone to create a killer high end transportHide this!Advertise here!
Shigaclone transport Gallery bernhardn Digital Source 17 18th August 2014 04:36 PM
JVC RC-EZ51 for SHIGACLONE High End Player MBA Swap Meet 0 4th March 2012 07:32 AM
WTB: Shigaclone CD transport mgf Swap Meet 1 4th June 2011 04:25 PM
shigaclone transport merlin2069er Swap Meet 3 28th March 2011 04:43 PM
shigaclone cd transport for sale patriz Swap Meet 2 23rd April 2008 02:59 PM
Copyright ©1999-2017 diyAudio
