Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Using the new 2012 Shigaclone to create a killer high end transport
Old 30th April 2013, 06:35 AM   #171
tvicol is offline tvicol  Romania
tvicol's Avatar
Using the new 2012 Shigaclone to create a killer high end transport Using the new 2012 Shigaclone to create a killer high end transport
Originally Posted by tonyptony View Post
Would you be able to advise as to how I would do this if I need to increase the vertical display angle?
You can increase vertical display or horizontal viewing angle up to a limit, as this is limited by crystal type - nematic - and manufacturing process. See below image from datasheet.
You can only force LC78601 to work LCD matrix at a lower voltage as I described in one of previous posts using median pin on a 2K pot connected at +5V and gnd.
Tibi
File Type: png Screenshot from 2013-04-30 09:32:47.png (39.4 KB, 325 views)
File Type: png Screenshot from 2013-04-30 09:33:22.png (32.2 KB, 323 views)
Vicol Audio
Old 30th April 2013, 03:09 PM   #172
tonyptony is offline tonyptony  United States
So if my voltage at Pin 40 is already 4.89 volts, it looks like I'm already at the maximum vertical viewing angle (assuming CR>=2). I'm not from the looks of this there is anything I can do.
Old 30th April 2013, 04:39 PM   #173
tvicol's Avatar
LCD can operate between 4.5 and 5.1 V.
You may try to adjust between these margins to get the best contrast and therefore viewing angle.
Tibi
Vicol Audio
Old 30th April 2013, 06:05 PM   #174
Tibi
How do I make the voltage go up?
Old 30th April 2013, 06:35 PM   #175
tvicol's Avatar
As far I undestand you power this section from a separate LT1086, therefore you may increase his output. This can be achieved by changing R50.
The mathematic relation is on LT1086 datasheet page 9.
Vout=Vref(1+R50/R51)+Iadj*R50
5.1=1.25(1+R50/120)+0.00005*R50
R50=(5.1-1.25)/(1.25/120+0.00005
R50~372ohm
Tibi
Vicol Audio
Old 30th April 2013, 10:12 PM   #176
Let me make sure I understand this. If I want to increase the voltage at LC78601 Pin 40, to improve the vertical viewing angle of the LCD, I have to increase the 5V supply across the entire 5V section of the board (if using just one 5V supply to the entire board)? Or if I don't do that, I'd have to put a separate 5V supply to the LC78601 and make that > 5V?
Old 1st May 2013, 08:18 AM   #177
tvicol's Avatar
Yes, both statements are wright.
Tibi
Vicol Audio
Old 1st May 2013, 01:27 PM   #178
If I use one 5V supply for the PCB, what is the maximum safe output voltage for the most senstive part in the chain?
Old 1st May 2013, 02:36 PM   #179
tvicol's Avatar
As per LC78601 and LA9242 datasheets, both have a maximum allowed 7V for all power supply pins, but normal operation is given between 4.5V and 5.5V. Stay between these values.
Tibi
Vicol Audio
Old 16th May 2013, 02:04 AM   #180
Tibi, Guido Tent has made it very clear in his experience that the clock will work best if fed from its own 5V supply. so okay, how do I do this?
8V supply for mechanism only - remove L4
Separate 5V supply for clock - ?
Separate 5V supply for everything else needing 5V - ?
Using the new 2012 Shigaclone to create a killer high end transportHide this!Advertise here!
Shigaclone transport Gallery bernhardn Digital Source 17 18th August 2014 03:36 PM
JVC RC-EZ51 for SHIGACLONE High End Player MBA Swap Meet 0 4th March 2012 06:32 AM
WTB: Shigaclone CD transport mgf Swap Meet 1 4th June 2011 03:25 PM
shigaclone transport merlin2069er Swap Meet 3 28th March 2011 03:43 PM
shigaclone cd transport for sale patriz Swap Meet 2 23rd April 2008 01:59 PM
Copyright ©1999-2017 diyAudio
