Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Using the new 2012 Shigaclone to create a killer high end transport
Old 27th April 2013, 11:39 AM   #161
tonyptony is offline tonyptony  United States
Originally Posted by tvicol View Post
Normally if you put a switch on LC78601 pin 40 - Vlcd1. This should allow you to switch on/off internal lcd mux.
tibi
Hmm, if I desolder that pad and lift it from the PCB, would I be able to use that small test point that you provided nearby as the other end, using a switch to close that circuit?
Old 28th April 2013, 05:14 PM   #162
For a separate 5V supply feeding the DSP and clock, how much better would a Bobken be over making a 5V version of the supply PCB that comes with the Tibi Shiga? In both cases I would be using the recommended BGs for the 2000 & 1000.
Old 28th April 2013, 08:50 PM   #163
In fact it adds, but I had to jump from a 3400euro (Vienna-Acoustics) speaker set, to a 9000euro (Triangle Magellan) to get the difference.
So far the biggest Shiga improvements I found are:
- Tentlabs clock
- separate power supply for Tentlabs clock
- changing S/PDIF output resistors to Vishay VAR-Series "naked" Z-FOIL
- replacing L7808 reg with LT1086-adj. Please add a 47uF tantalum over R50
- add C11 - 1nF silver-mica
Tibi
Tibi, the Linear Technologies app guide recommends nothing higher than about 22uF tantalum for the PS cap. Is there a reason why you feel 47uF works better? Also, for C11 can I use the same cap that is recommended for C66? What is C11 in the delivered Shiga package?
Old 28th April 2013, 09:12 PM   #164
The display angle is wider and therefore more readable.
The method described above is an alternative to the method presented in Shiga documentation.
Already moded boards do not need this.
Tibi
Tibi, I'd like to discuss this further. I measured 4.89V at the referenced point on thr PCB. Yet my vertical display angle is still not great. On your website you describe the LCD as having multiple bias points. What does that mean? Can I "change" to one of these other bias points?
Old 29th April 2013, 04:19 PM   #165
tvicol is offline tvicol  Romania
tvicol's Avatar
Using the new 2012 Shigaclone to create a killer high end transport Using the new 2012 Shigaclone to create a killer high end transport
22uF is ensure stability over 60Hz, Under 60Hz you need a higher capacitor - see datasheet page 7 first graph. C11 is an optional capacitor for Vref=2.5V. In case you are using one this must be silver-mica ~1nF.
Tibi
Vicol Audio
Old 29th April 2013, 04:29 PM   #166
tvicol's Avatar
You can adjust further. Datasheet value is 4.8V, but you may adjust up to your best view.
The LCD is multiplexed on each segment and for this the LC78601 is using 3 bias points between 0 and 5V.
ex:
- 0V
- 1.5V
- 2.5V
- 3.5V
- 5V
This way, the life of LCD is highly prolonged. It's an old technique used mainly in displays with many digits - like scientific calculators.
These bias points can not be changed. Some time ago I posted some graphs and oscillographs.
If fact, this was the main reason why this project took so long, as we had to design and manufacture a custom LCD.
Tibi
Vicol Audio
Old 29th April 2013, 04:59 PM   #167
Would you be able to advise as to how I would do this if I need to increase the vertical display angle?
Old 29th April 2013, 05:02 PM   #168
Tibi
So the 47uF is for supplies operating in a 50Hz environment?
Old 29th April 2013, 11:25 PM   #169
Okay, here is my plan of replacement parts and upgrades in my attempt to make my next Shigaclone a la Tibi. All this is based on reading through the Shiga thread (and others) and from help by everyone here.
  1. Add separate 5V supply for the digital part of the PCB and clock - either an upgraded 5V version of Tibi's or a Bobken.
  2. Using a custom 40VA R-core transformer for the 5V supply (from a project that never was).
  3. Probably going to go with a Tent Labs clock.
  4. Using BG F and FK for the 1000uF and 2200uF caps (C64 and C63) on the PS.
  5. Upgrading the stock 8V supply with BG FK in place of the 2200uF (C63) and maybe Os-Con or Elna Starget for C64 (I have only 1 BG "F" ).
  6. Replacing C66 in both supplies with silver mica.
  7. Silver mica for C11
  8. Replacing C63 on the PCB with a BG 47uF NX.
  9. Using uncle_leon's Ivisistor pi-pad for the 75 Ohm output of the board.
  10. Still not sure what to do about C8.
  11. Still not sure what to do about C10, C17, C19.
Anything else?
Old 30th April 2013, 06:02 AM   #170
tvicol's Avatar
Yes, should cover both 50 and 60Hz.
Tibi
Vicol Audio
Using the new 2012 Shigaclone to create a killer high end transportHide this!Advertise here!
Shigaclone transport Gallery bernhardn Digital Source 17 18th August 2014 03:36 PM
JVC RC-EZ51 for SHIGACLONE High End Player MBA Swap Meet 0 4th March 2012 06:32 AM
WTB: Shigaclone CD transport mgf Swap Meet 1 4th June 2011 03:25 PM
shigaclone transport merlin2069er Swap Meet 3 28th March 2011 03:43 PM
shigaclone cd transport for sale patriz Swap Meet 2 23rd April 2008 01:59 PM
Copyright ©1999-2017 diyAudio
